[mapserver-dev] MapServer Config File RFC
Steve Lime
sdlime at gmail.com
Tue Oct 12 10:28:06 PDT 2021
It's a hypothetical use case and hasn't been implemented as part of the
RFC. Specifically that statement It is referencing a poorly documented
feature where you can do something like:
WEB
VALIDATION
"immutable" "true"
END
END
and then no runtime changes are allowed. I'm not sure how relevant it will
be for 8.0 because I'd like to make this the default behavior (immutable).
I think there are a number of potential uses of the config file that
haven't been fully explored. One demonstration use case I did address is
setting a value in the ENV section called MS_NO_POST so that MapServer
won't read params from the request post body. That is in the pull request.
--Steve
On Tue, Oct 12, 2021 at 11:54 AM Even Rouault <even.rouault at spatialys.com>
wrote:
> Steve,
> "all mapfiles could be defined as immutable, so no runtime changes would
> be allowed site-wide" : is this in the scope of the RFC ? What does this
> refer to ?
> Even
> Le 12/10/2021 à 18:39, Steve Lime a écrit :
> It's been a month so it's time to call for a vote on this addition to the
> 8.0. The links to the RFC and pull request are below... Still time for
> comments and code review but we need to get this feature added to main.
> I'll start with a +1. --Steve
> On Tue, Sep 14, 2021 at 1:30 PM Jeff McKenna <
> jmckenna at gatewaygeomatics.com> wrote:
>> On my front burner now. -jeff
>> On 2021-09-14 2:10 p.m., Steve Lime wrote:
>> > Kinda quiet on this one... Has anyone had time to test it out? --Steve
>> > On Tue, Sep 7, 2021 at 10:36 PM Steve Lime <sdlime at gmail.com
>> > <mailto:sdlime at gmail.com>> wrote:
>> > Hi all: Jeff converted my draft RFC to the more standard format a
>> > week ago and I spaced letting folks know - thanks Jeff! Anyway, it's
>> > out there for review at:
>> > https://mapserver.org/development/rfc/ms-rfc-135.html
>> > <https://mapserver.org/development/rfc/ms-rfc-135.html>
>> > Please take a look and let me know what you think. There is a pull
>> > request at:
>> > https://github.com/MapServer/MapServer/pull/6303
>> > <https://github.com/MapServer/MapServer/pull/6303>
>> > and I encourage folks to try it. It really should make site
>> > configuration easier across multiple types of deployments.
>> > --Steve
>> MapServer-dev mailing list
>> MapServer-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
> MapServer-dev mailing listMapServer-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/mapserver-dev
> -- http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20211012/c71b4db8/attachment-0001.html>
More information about the MapServer-dev
