[mapserver-dev] Proposal/request to implement FlatGeobuf as built-in format
Even Rouault even.rouault at spatialys.com
Wed Apr 27 10:09:53 PDT 2022
Jeff,
as a data point, perhaps you could enhance your bench with shapefiles
through OGR ? It would be interesting to have a sense of the OGR
overhead (that will be the same for any OGR supported datasource) to
have an idea if it is really worth the effort to have a native
FlatGeobuf provider for MapServer w.r.t going through OGR (it is hard to
beat shapefile, and the current difference between shapefile and
flatgeobuf is small)
Even
Le 26/04/2022 à 12:57, Jeff McKenna a écrit :
> (to followup from our chat on IRC yesterday)
> To clarify: this would be a new native format in MapServer, such as
> Shapefile or PostGIS, and the goal would be to not connect to
> FlatGeobuf through OGR, but instead directly, such as:
>   DATA countries.fgb
> instead of:
>   CONNECTIONTYPE OGR
>   CONNECTION "countries.fgb"
>   DATA "countries"
> This should improve the performance even more.  And it will be easy to
> update the documentation, as the existing files just need to be
> updated (see the new page at
> https://mapserver.org/input/vector/flatgeobuf.html )
> Great plan Björn!  I look forward to your Pull Request, ha, and will
> tackle the documentation changes for you.
> This is also great news for MapServer, and will give us some nice
> publicity.
> Thanks so much!
> -jeff
> On 2022-04-25 5:57 p.m., Björn Harrtell wrote:
>> Hi mapserver devs!
>> I got interested in the subject because of the tests made recently by
>> Jeff that shows the potential of the format. I believe it should be
>> possible to get significant additional performance out of FlatGeobuf
>> in MapServer if it was built in just like Shapefile support is.
>> FlatGeobuf C++ implementation is rather small, doesn't require any
>> dependencies, and I don't expect it to require any invasive changes
>> to existing code.
>> Would love to get started on this ASAP, if there are no objections. :)
>> Regards,
>> Björn Harrtell
>> MapServer-dev mailing list
>> MapServer-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
http://www.spatialys.com
More information about the MapServer-dev mailing list
