[mapserver-dev] Mapserver 8.0 beta documentation
Richard Greenwood
richard.greenwood at gmail.com
Tue Aug 16 08:29:11 PDT 2022
So an improved comment might be "Required when referencing map file(s) by
path".
On Tue, Aug 16, 2022 at 8:15 AM Steve Lime <sdlime at gmail.com> wrote:
> Ok, then that is expected. If you pass a map with a file path then (and
> assuming you haven't set MS_MAP_NO_PATH) you should see the error message
> Jeff referenced.
> On Tue, Aug 16, 2022 at 8:27 AM Richard Greenwood <
> richard.greenwood at gmail.com> wrote:
>> On Tue, Aug 16, 2022 at 7:10 AM Steve Lime <sdlime at gmail.com> wrote:
>>> There are 2 scenarios when you won't get the error Jeff references
>>> when MS_MAP_PATTERN is not set in the config file:
>>> 1. If using an map alias (set in the map section of the config file)
>>> - these can only be read from the config file.
>>> 2. If MS_MAP_PATTERN is set in the underlying environment - that is,
>>> by the web server. Things are set up to fall back to the environment
>>> variables (we're using GDAL functionality) if they exist for any of the MS*
>>> variables.
>>> Do either of these apply?
>> Yep, I'm using aliases in the MAP section.
>>> On Tue, Aug 16, 2022 at 7:31 AM Richard Greenwood <
>>>> Sorry I missed the TEMPLATEPATTERN documentation (reading too quickly
>>>> in all the excitement over a new MS version)!
>>>> Regarding MS_MAP_PATTERN, I'm doing a WMS GetMap request.
>>>> Rich
>>>> On Tue, Aug 16, 2022 at 6:07 AM Jeff McKenna <
>>>> jmckenna at gatewaygeomatics.com> wrote:
>>>>> (I tested in my browser with a CGI MODE=map call)
>>>>> -jeff
>>>>> On 2022-08-16 9:05 a.m., Jeff McKenna wrote:
>>>>> > Hi Rich,
>>>>> > I just tested the 8.0.0-beta2 and it is in fact required: "Web
>>>>> > application error. Required configuration value MS_MAP_PATTERN not
>>>>> set".
>>>>> > -jeff
>>>>> > On 2022-08-16 9:00 a.m., Jeff McKenna wrote:
>>>>> >> Hi Rich,
>>>>> >> Correct, TEMPLATEPATTERN was removed (this is already noted in the
>>>>> >> documentation at https://mapserver.org/mapfile/map.html ). If you
>>>>> see
>>>>> >> it mentioned elsewhere please let me know.
>>>>> >> Regarding MS_MAP_PATTERN, let's let SteveL respond here, and I will
>>>>> >> correct the docs (as throughout this 8.0 process I always assumed
>>>>> it
>>>>> >> was now required).
>>>>> >> Thanks,
>>>>> >> -jeff
>>>>> _______________________________________________
>>>>> MapServer-dev mailing list
>>>>> MapServer-dev at lists.osgeo.org
>>>>> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
>>>> Richard W. Greenwood
>>>> www.greenwoodmap.com
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20220816/581590f1/attachment-0001.htm>
More information about the MapServer-dev
