[mapserver-dev] Question about the bad mapfile pattern (vulnerability) check
Tamas Szekeres
szekerest at gmail.com
Thu Feb 10 11:05:20 PST 2022
Steve,
I think we cannot avoid to be platform dependent in this regard. A single
slash at the beginning on Windows systems should not be accepted, because
it can specify a relative path, however a double back slash at the
beginning is accepted (absolute path of a network share). Currently the
single slash at the beginning is accepted in all platforms.
Applying environment variables might not be a trivial task in all run time
environments, so I think the default behavior should work in that way which
can do the right thing in most use cases.
Best regards,
Tamas
Steve Lime <sdlime at gmail.com> ezt írta (időpont: 2022. febr. 10., Cs,
15:48):
> The idea was to limit things to local paths with no back references by
> default. We're not distinguishing between OSes in setting that pattern.
> It's possible it's a bit overzealous so we could tweak the default if that
> makes sense across operating systems. It can be overridden by
> environment variable (or within the config file) and could be turned off
> completely with an expression that will never match.
> On Thu, Feb 10, 2022 at 4:34 AM Tamas Szekeres <szekerest at gmail.com>
> wrote:
>> Hi Developers,
>> I noticed that the double back slashes are excluded from the accepted
>> mapfile pattern in one of the commits not too long ago according to
>> security vulnerability reasons. The bad patten regex is now looking like:
>> const char *ms_map_bad_pattern_default = "[/\\]{2}|[/\\]?\\.+[/\\]|,";
>> Do we have a specific reason why we don't accept the double back slashes
>> at the beginning of the mapfile path? This normally refers to a network
>> share which is considered to be an absolute path, and our use cases are
>> working like that extensively. I guess we wanted to exclude the relative
>> paths basically, but it seems not to be that case.
>> I'm also wondering if the double forward slashes at the beginning makes
>> much sense to exclude, since I think that is treated as a single forward
>> slash in the unix like systems which is normally accepted.
>> Thanks,
>> Tamas
>> MapServer-dev mailing list
>> MapServer-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20220210/66d2246b/attachment.html>
More information about the MapServer-dev
