[mapserver-dev] Question about the bad mapfile pattern (vulnerability) check
Jeff McKenna
jmckenna at gatewaygeomatics.com
Thu Feb 10 12:18:18 PST 2022
I suppose that is another performance hit. So cancel that one, ha.
Anyway, I do think it's good to discuss the issues, even if nothing else
can be done.
I'll continue to tackle this on the packaging side.
-jeff
On 2022-02-10 4:09 p.m., Jeff McKenna wrote:
> For example (me thinking out of the box), could the MapServer config
> file contain a section where users can specify paths or characters to
> disallow (not a regular expression), and then MapServer would convert
> that to a regular expression (in either PCRE or libregex syntax) and
> apply it at run-time.
> -jeff
> On 2022-02-10 4:00 p.m., Jeff McKenna wrote:
>> The tricky part here is that most recent packages use the PCRE regular
>> expression library, because of its open BSD license, but the "bad"
>> pattern hardcoded into the MapServer source is for libregex, which is
>> GPL based, and that expression won't work with the PCRE engine.
>> My thoughts were when the idea of a "MapServer config file" coming,
>> was that phew, then users can just point to their valid mapfiles there
>> with simple paths or even wildcard paths or directories, and we can
>> completely remove that bad pattern stuff from the source code.
>> So I assumed that the new config file would save us. In fact the
>> config file is just another place to put the bad pattern, which,
>> honestly most MapServer users will never understand nor have the time
>> to understand.
>> I am wondering, when we re-look at the bad pattern stuff, if we can
>> think of a way that the new config file can replace the hardcoding
>> inside the MapServer source.
>> I hope it's ok to wonder here out loud, ha.
>> -jeff
>> On 2022-02-10 3:05 p.m., Tamas Szekeres wrote:
>>> Steve,
>>> I think we cannot avoid to be platform dependent in this regard. A
>>> single slash at the beginning on Windows systems should not be
>>> accepted, because it can specify a relative path, however a double
>>> back slash at the beginning is accepted (absolute path of a network
>>> share). Currently the single slash at the beginning is accepted in
>>> all platforms.
>>> Applying environment variables might not be a trivial task in all run
>>> time environments, so I think the default behavior should work in
>>> that way which can do the right thing in most use cases.
>>> Best regards,
>>> Tamas
>>> Steve Lime <sdlime at gmail.com <mailto:sdlime at gmail.com>> ezt írta
>>> (időpont: 2022. febr. 10., Cs, 15:48):
>>> The idea was to limit things to local paths with no back references
>>> by default. We're not distinguishing between OSes in setting that
>>> pattern. It's possible it's a bit overzealous so we could tweak the
>>> default if that makes sense across operating systems. It can be
>>> overridden by environment variable (or within the config file) and
>>> could be turned off completely with an expression that will never
>>> match.
>>> On Thu, Feb 10, 2022 at 4:34 AM Tamas Szekeres <szekerest at gmail.com
>>> <mailto:szekerest at gmail.com>> wrote:
>>> Hi Developers,
>>> I noticed that the double back slashes are excluded from the
>>> accepted mapfile pattern in one of the commits not too long ago
>>> according to security vulnerability reasons. The bad patten
>>> regex is now looking like:
>>> const char *ms_map_bad_pattern_default =
>>> "[/\\]{2}|[/\\]?\\.+[/\\]|,";
>>> Do we have a specific reason why we don't accept the double back
>>> slashes at the beginning of the mapfile path? This normally
>>> refers to a network share which is considered to be an absolute
>>> path, and our use cases are working like that extensively. I
>>> guess we wanted to exclude the relative paths basically, but it
>>> seems not to be that case.
>>> I'm also wondering if the double forward slashes at the
>>> beginning makes much sense to exclude, since I think that is
>>> treated as a single forward slash in the unix like systems which
>>> is normally accepted.
>>> Thanks,
>>> Tamas
>>> MapServer-dev mailing list
>>> MapServer-dev at lists.osgeo.org
>>> <mailto:MapServer-dev at lists.osgeo.org>
>>> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
>>> <https://lists.osgeo.org/mailman/listinfo/mapserver-dev>
Jeff McKenna
GatewayGeo: Developers of MS4W, MapServer Consulting and Training
co-founder of FOSS4G
http://gatewaygeo.com/
More information about the MapServer-dev
