[mapserver-dev] Issue on installing Mapserver 7.6.4 on Ubuntu 20.04: ProtobufC
Jeff McKenna
jmckenna at gatewaygeomatics.com
Tue Jan 18 07:31:20 PST 2022
Hi Francesco,
For my Ubuntu servers (which includes for demo.mapserver.org) I install
the following:
sudo apt-get install libprotobuf-dev libprotobuf-c-dev
protobuf-c-compiler
Maybe you could try that as well.
-jeff
Jeff McKenna
GatewayGeo: Developers of MS4W, MapServer Consulting and Training
co-founder of FOSS4G
http://gatewaygeo.com/
On 2022-01-18 11:09 a.m., Francesco Martinelli wrote:
> Hi all,
> I am trying to compile *Mapserver* on *Ubuntu 20.04*.
> I have the following cmake version:
> *cmake version 3.16.3*
> I have a problem during the cmake phase that is reported to be caused by
> ProtobufC
> Here is the package I think should be installed:
> $ *sudo apt-get install libprotobuf-dev*
> Reading package lists... Done
> Building dependency tree
> Reading state information... Done
> *libprotobuf-dev is already the newest version* (3.6.1.3-2ubuntu5).
> libprotobuf-dev set to manually installed.
> 0 upgraded, 0 newly installed, 0 to remove and 3 not upgraded.
> I made no changes to the CMakeLists.txt coming with the distribution,
> but WITH_PYTHON and WITH_JAVA options.
> Below is the result from the cmake command.
> Please can someone drive me on what is wrong?
> Thank you,
> Francesco
> $ cmake ..
> -- Requiring C++11
> -- Requiring C++11 - done
> -- Requiring C99
> -- Requiring C99 - done
> -- Could NOT find ProtobufC (missing: PROTOBUFC_LIBRARY
> PROTOBUFC_COMPILER PROTOBUFC_INCLUDE_DIR)
> CMake Error at CMakeLists.txt:91 (message):
> PROTOBUFC library/component/dependency could not be found.
> HINTS:
> - disable PROTOBUFC support by adding -DWITH_PROTOBUFC=0
> - add the PROTOBUFC install directory to the CMAKE_PREFIX_PATH variable
> (-DCMAKE_PREFIX_PATH="/path/to/PROTOBUFC-install-dir;/path/to/other/dirs"
> Call Stack (most recent call first):
> CMakeLists.txt:312 (report_optional_not_found)
> -- Found Proj 6.3
> -- Could NOT find PY_setuptools (missing: PY_SETUPTOOLS)
> -- CMake Version: 3.16
> -- Build Type:
> -- Python MapScript output directory:
> /home/francesco/Software/Mapserver/mapserver-7.6.4/build/mapscript/python
> -- Python Executable: /usr/bin/python
> -- Python site packages: /usr/lib/python2.7/dist-packages
> -- * Summary of configured options for this build
> -- * Mandatory components
> -- * GDAL: /usr/lib/libgdal.so
> -- * PROJ: /usr/lib/x86_64-linux-gnu/libproj.so
> -- * png: /usr/lib/x86_64-linux-gnu/libpng.so
> -- * jpeg: /usr/lib/x86_64-linux-gnu/libjpeg.so
> -- * freetype: /usr/lib/x86_64-linux-gnu/libfreetype.so
> -- * Optional components
> -- * GIF: /usr/lib/x86_64-linux-gnu/libgif.so
> -- * MYSQL: disabled
> -- * FRIBIDI: /usr/lib/x86_64-linux-gnu/libfribidi.so
> -- * HARFBUZZ: /usr/lib/x86_64-linux-gnu/libharfbuzz.so
> -- * CAIRO: /usr/lib/x86_64-linux-gnu/libcairo.so
> -- * SVGCAIRO: disabled
> -- * RSVG: disabled
> -- * CURL: disabled
> -- * PIXMAN: disabled
> -- * LIBXML2: /usr/lib/x86_64-linux-gnu/libxml2.so
> -- * POSTGIS: /usr/lib/x86_64-linux-gnu/libpq.so
> -- * GEOS: /usr/lib/x86_64-linux-gnu/libgeos_c.so
> -- * FastCGI: /usr/lib/x86_64-linux-gnu/libfcgi.so
> -- * PROTOBUFC: disabled
> -- * Oracle Spatial: disabled
> -- * Exempi XMP: disabled
> -- * Optional features
> -- * WMS SERVER: ENABLED
> -- * WFS SERVER: ENABLED
> -- * WCS SERVER: ENABLED
> -- * SOS SERVER: disabled
> -- * WMS CLIENT: disabled
> -- * WFS CLIENT: disabled
> -- * ICONV: ENABLED
> -- * Thread-safety support: disabled
> -- * KML output: disabled
> -- * Z+M point coordinate support: ENABLED
> -- * XML Mapfile support: disabled
> -- * Mapscripts
> -- * Python: ENABLED
> -- * PHP: disabled
> -- * PHPNG: disabled
> -- * PERL: disabled
> -- * RUBY: disabled
> -- * JAVA: ENABLED
> -- * C#: disabled
> -- * V8 Javascript: disabled
> -- * Apache Module (Experimental): disabled
> -- PROJECT_BINARY_DIR is set to
> -- Will install files to /usr/local
> -- Will install libraries to /usr/local/lib
> -- Configuring incomplete, errors occurred!
> See also
> "/home/francesco/Software/Mapserver/mapserver-7.6.4/build/CMakeFiles/CMakeOutput.log".
> See also
> "/home/francesco/Software/Mapserver/mapserver-7.6.4/build/CMakeFiles/CMakeError.log".
> MapServer-dev mailing list
> MapServer-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
More information about the MapServer-dev
