[mapserver-dev] msPostGISLayerWhichShapes() Error : java library set wrong query
Francesco Martinelli
francesco.martinelli at ingv.it
Thu Jan 27 04:27:51 PST 2022
Thank you Jukka for your support,
but what suggested do not solve the problem.
Probably I need a programmer/developer to look into *mapscriptJNI* and let
me know how to solve this issue.
Francesco
Il giorno gio 27 gen 2022 alle ore 13:09 Rahkonen Jukka (MML) <
jukka.rahkonen at maanmittauslaitos.fi> ha scritto:
> Hi,
> I am not a programmer but I would still imagine that if netBeans knows how
> to read the locale that your computer is using there might also be a method
> to set the locale. Is this of any help
> https://stackoverflow.com/questions/9190404/change-locale-in-netbeans-platform-application?
> Sorry if I am disoriented.
> -Jukka Rahkonen-
> *Lähettäjä:* Francesco Martinelli <francesco.martinelli at ingv.it>
> *Lähetetty:* torstai 27. tammikuuta 2022 13.39
> *Vastaanottaja:* Rahkonen Jukka (MML) <jukka.rahkonen at maanmittauslaitos.fi
> *Kopio:* MapServer Dev List <mapserver-dev at lists.osgeo.org>
> *Aihe:* Re: [mapserver-dev] msPostGISLayerWhichShapes() Error : java
> Hi Jukka,
> I use the library within a web application not a desktop application.
> At the moment I am developing with NetBeans: I don't find any place where
> to specify the numeric separator.
> However, the faulty code in *mapObj.java:397* is
> *long cPtr = mapscriptJNI.mapObj_draw(swigCPtr, this);*
> and *mapscriptJNI* is generated by SWIG, which is a C/C++ wrapper, so the
> JAVA_OPT is unlikely to be used.
> Francesco
> Il giorno gio 27 gen 2022 alle ore 12:13 Rahkonen Jukka (MML) <
> Hi,
> Have you considered to change the locale with your own code as first aid?
> I do not know how to do that but some desktop application seems to do that
> with Java options
> rem --- uncomment and change your language/country here to overwrite OS
> locale setting ---
> set JAVA_OPTS=%JAVA_OPTS% -Duser.language=en -Duser.country=EN
> -Jukka Rahkonen-
> *Lähettäjä:* MapServer-dev <mapserver-dev-bounces at lists.osgeo.org> *Puolesta
> *Francesco Martinelli
> *Lähetetty:* torstai 27. tammikuuta 2022 12.07
> *Vastaanottaja:* MapServer Dev List <mapserver-dev at lists.osgeo.org>
> *Aihe:* [mapserver-dev] msPostGISLayerWhichShapes() Error : java library
> set wrong query
> Dear developers,
> I have an issue with the java library on the call to *mapObj.draw()*, of *mapserver
> 7.6.4*, compiled and running on Ubuntu 20.04
> Apparently it is "sensible" to the locale which is:
> $ localectl
> System Locale: LANG=it_IT.UTF-8
> VC Keymap: n/a
> X11 Layout: it
> X11 Model: pc105
> $ locale -c decimal_point
> LC_NUMERIC
> I already asked the mapserver-users list, but without success.
> *Here is the code*:
> mapObj myMap = new mapObj("myMapFile.map");
> rectObj originalMapView = myMap.getExtent();
> rectObj maxView = new rectObj(-1, -1, -1, -1,
> myMap.getUnits().swigValue());
> maxView.setMinx(originalMapView.getMinx());
> maxView.setMaxx(originalMapView.getMaxx());
> maxView.setMiny(originalMapView.getMiny());
> maxView.setMaxy(originalMapView.getMaxy());
> rectObj myView = new rectObj(-1, -1, -1, -1, 3);
> myView.setMinx(*774076.75*);
> myView.setMaxx(*1014076.75*);
> myView.setMiny(*4875124.5*);
> myView.setMaxy(*5115124.5*);
> myMap.setExtent(myView);
> myMap.setSize(600, 600);
> pointObj mousePosition = new pointObj(300, 300, 0);
> myMap.zoomPoint(1, mousePosition, 600, 600, myView, maxView);
> myMap.draw();
> *resulting in the error*:
> *java.lang.UnknownError: msDrawMap():* Image handling error. Failed to
> draw layer named 'MyLayer'.;*msPostGISLayerWhichShapes(): Query error*.
> Error executing query. Check server logs
> edu.umn.gis.mapscript.mapscriptJNI.mapObj_draw(Native Method)
> edu.umn.gis.mapscript.mapObj.draw(mapObj.java:397)
> *and in the ERROR file*:
> [Wed Jan 26 17:14:19 2022].569532 msPostGISLayerWhichShapes(): Error
> (ERROR: parse error - invalid geometry
> HINT: "POLYGON((774076,75" <-- parse error at position 18 within geometry
> ) executing query: select
> "my_column"::text,ST_AsBinary(("the_geom"),'NDR') as geom,"gid"::text from
> (SELECT * FROM classi_comuni WHERE tipo_area = 2 ORDER BY tipo_area DESC)
> AS confini where "the_geom" && ST_GeomFromText('*POLYGON((774076,75
> 4875124,5,774076,75 5115124,5,1014076,75 5115124,5,1014076,75
> 4875124,5,774076,75 4875124,5))*
> ',find_srid('','classi_comuni','the_geom'))
> As far as I understand the correct query should be (in *red* the changes):
> select "my_column"::text,ST_AsBinary(("the_geom"),'NDR') as
> geom,"gid"::text from (SELECT * FROM classi_comuni WHERE tipo_area = 2
> ORDER BY tipo_area DESC) AS confini where "the_geom" && ST_GeomFromText('*POLYGON((774076.75
> 4875124.5,774076.75 5115124.5,1014076.75 5115124.5,1014076.75
> 4875124.5,774076.75 4875124.5*
> ))',find_srid('','classi_comuni','the_geom'))
> I think the following parameters in mapfile could be of interest to you:
> CONFIG "MS_ERRORFILE" "myfile"
> DEBUG 6
> LAYER
> CONNECTIONTYPE postgis
> DATA "the_geom FROM (SELECT * FROM classi_comuni WHERE tipo_area =
> 2 ORDER BY tipo_area DESC) AS confini USING UNIQUE gid"
> CLASSITEM "my_column"
> Please could you help?
> Thank you,
> Francesco
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20220127/01a4a932/attachment.html>
More information about the MapServer-dev
