[mapserver-dev] Projections and CONFIG file in MapServer 8.0
Steve Lime
sdlime at gmail.com
Wed Jul 6 13:49:58 PDT 2022
This could/would have been the case in past versions as well, right? So I
don't think this is a new issue. IMHO I'd think central config settings
should trump local settings for something like this.
On Wed, Jul 6, 2022 at 2:40 PM Seth G <sethg at geographika.co.uk> wrote:
> Hi all,
> Using MapServer 8.0 beta and FastCGI (on Windows) I'm running into an
> issue where the PROJ_LIB setting is sometimes set by the value in the
> CONFIG file and sometimes by the setting in the Mapfile:
> CONFIG
> ENV
> MS_MAP_PATTERN "."
> PROJ_LIB "C:/MapServer/bin/proj7/share" #proj7
> END
> END
> Then in a Mapfile:
> CONFIG "PROJ_LIB" "C:/MapServer/bin/proj/SHARE" # uses proj6
> Requests will use one PROJ setting then switch to another seemingly at
> random.
> Should one always take precedence over the other?
> Seth
> web:https://geographika.net
> twitter: @geographika
> MapServer-dev mailing list
> MapServer-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20220706/356b1e7c/attachment.htm>
More information about the MapServer-dev
