[mapserver-dev] Projections and CONFIG file in MapServer 8.0
Seth G
sethg at geographika.co.uk
Thu Jul 7 06:02:34 PDT 2022
Thanks, Steve and Jeff for the feedback.
As system environment variables never worked with IIS (only FastCGI environment variables) I was only ever able to configure PROJ_LIB in a Mapfile.
Logically, I'd assume a Mapfile would override a CONFIG setting, as it is the last/top setting. However, as PROJ_LIB can be used to load a DLL from any location then I can see why it would make sense to lock it down in the CONFIG file.
I'll have a dig into the code to see why it sometimes uses one and sometimes the other setting - ideally we'd make a call on which has priority and make sure it works consistently.
Seth
web:https://geographika.net
twitter: @geographika
On Thu, Jul 7, 2022, at 1:27 AM, Jeff McKenna wrote:
> I can dream of a 'PROJ_LIB_LOCATION_PRIORITY' setting in the MapServer
> .conf file:
> 1 : use .conf setting
> 2 : use setting inside your .mapfile or .include
> 3 : use setting from Web Server (Apache conf, etc.)
> 4 : use setting at the System environment level [warning to Windows
> Server admins, this is problematic on some systems in several ways:
> often not found, or conflicts with other FOSS4G software settings for PROJ]
> Or, the old rule applies here: 'never send an important email after 6pm' ha!
> Thanks for listening,
> -jeff
> On 2022-07-06 8:12 p.m., Jeff McKenna wrote:
>> Ok thanks Steve, but can you be more specific regarding 'local setting'?
>> On Windows each FOSS4G software has its own PROJ instance/version and
>> its own PROJ_LIB variable (yes it's complete disaster, waiting to
>> happen). So where does the mapfile's PROJ_LIB setting, and then the
>> System environment variable fit into your 3 ?
>> Thanks,
>> -jeff
>> On 2022-07-06 6:44 p.m., Steve Lime wrote:
>>> I understand your logic and would agree for most things. However, one
>>> benefit of the config file is to allow admins to lock things down -
>>> especially items like environment variable settings that tell
>>> MapServer to load code. Hence my original response, so 1) config file,
>>> 2) web server environment, 3) local setting.
>>> --Steve
>>> On Wed, Jul 6, 2022 at 4:05 PM Jeff McKenna
>>> <jmckenna at gatewaygeomatics.com <mailto:jmckenna at gatewaygeomatics.com>>
>>> wrote:
>>> Oh don't forget PostGIS' use of that same variable (that's where I
>>> hit
>>> this on servers constantly).
>>> So, my point is, that the only way we can avoid all this
>>> "environment"
>>> variable chaos is first always use the local mapfile setting, then
>>> look
>>> for .conf, and if neither has this, check the other sources.
>>> -jeff
>>> On 2022-07-06 6:01 p.m., Jeff McKenna wrote:
>>> > I think we have several possibilities: environment var (system
>>> > variable), web server environment variable (Apache config),
>>> MapServer
>>> > .conf, and local mapfile setting.
>>> > I would say that the local mapfile should always be used first by
>>> > MapServer, in this order:
>>> > - check mapfile setting,
>>> > - if not found, check for MapServer .conf setting,
>>> > - if not found, check for web server setting
>>> > - if not found, check for system environment variable
>>> > - ...else, battle for superiority with the other PROJ_LIB
>>> settings by
>>> > the other FOSS4G software on that container
>>> > Notes:
>>> > - this shared PROJ_LIB issue is not just for MapServer, but is
>>> faced by
>>> > all FOSS4G projects that share this variable. On Windows servers
>>> now it
>>> > is common for me to have several PROJ_LIB settings, one for each
>>> FOSS4G
>>> > software that depends on (depends on that PROJ version for that
>>> > software), such as QGIS, GDAL, MapServer, etc. etc. Meaning: f
>>> you need
>>> > a job run for one software, enable that specific PROJ_LIB.
>>> > It's fun :)
>>> > -jeff
>>> > On 2022-07-06 5:49 p.m., Steve Lime wrote:
>>> >> This could/would have been the case in past versions as well,
>>> right?
>>> >> So I don't think this is a new issue. IMHO I'd think central
>>> config
>>> >> settings should trump local settings for something like this.
>>> >> On Wed, Jul 6, 2022 at 2:40 PM Seth G <sethg at geographika.co.uk
>>> <mailto:sethg at geographika.co.uk>
>>> <mailto:sethg at geographika.co.uk>>> wrote:
>>> >> Hi all,
>>> >> Using MapServer 8.0 beta and FastCGI (on Windows) I'm
>>> running into
>>> >> an issue where the PROJ_LIB setting is sometimes set by the
>>> value in
>>> >> the CONFIG file and sometimes by the setting in the Mapfile:
>>> >> CONFIG
>>> >> ENV
>>> >> MS_MAP_PATTERN "."
>>> >> PROJ_LIB "C:/MapServer/bin/proj7/share" #proj7
>>> >> END
>>> >> END
>>> >> Then in a Mapfile:
>>> >> CONFIG "PROJ_LIB" "C:/MapServer/bin/proj/SHARE" # uses proj6
>>> >> Requests will use one PROJ setting then switch to another
>>> seemingly
>>> >> at random.
>>> >> Should one always take precedence over the other?
>>> >> Seth
>>> >> web:https://geographika.net <https://geographika.net>
>>> <https://geographika.net <https://geographika.net>>
>> MapServer-dev mailing list
>> MapServer-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
> Jeff McKenna
> GatewayGeo: Developers of MS4W, MapServer Consulting and Training
> co-founder of FOSS4G
> http://gatewaygeo.com/
More information about the MapServer-dev
