[mapserver-dev] Proposal/request to implement FlatGeobuf as built-in format
Lars Schylberg lars.schylberg at blixtmail.se
Wed May 18 12:07:46 PDT 2022
Thanks, Björn and Jeff for the effort to do this.I am eager to start
testing soon.As a user I feel that Santa is coming early this year.
I also have one question.Is the native FlatGeobuf driver doing the
reading without checks, like "VERIFY_BUFFERS" "NO" that you can set in
the OGR driver?
My inofficial +1
Lars Schylberg
Den 2022-05-18 kl. 17:09, skrev Steve Lime:
> Nice work all - esp. Björn. Evan has a good point that sounds like it
> could be addressed. Couple of comments:
>  1. I'd like to see a security impact section added just so it's clear
>     that it has been thought about. For example, what is behavior if a
>     corrupt, invalid or truncated file is accessed.
>  2. Does the flatgeobuf directory contain only code specific to
>     MapServer or is there a mix of custom code and 3rd party code? If
>     there is 3rd party code could there be a discussion about how that
>     should be maintained over time?
>  3. Are things pinned to a particular version of flatbuf - I assume
>     yes and that should be noted.
>  4. I'm assuming there are no MapScript issues - might be nice to
>     explicitly state that.
> --Steve
> On Wed, May 18, 2022 at 6:38 AM Even Rouault
> <even.rouault at spatialys.com> wrote:
>     I'm 0 on this. While this is always nice to see a perf
>     improvement, I'm
>     somewhat concerned by the duplication of code between MapServer
>     and GDAL.
>     And from a purely technical point of view, one of my worry is that
>     symbol clashes might occur between GDAL and MapServer on the
>     common code
>     they share in the FlatGeobuf and flatbuffers C++ namespaces. If the
>     implementations are not kept in sync (and that will necessarily
>     happen
>     at some point because we cannot control which GDAL version is used by
>     MapServer), weird things (crashes) could possibly happen at
>     runtime (or
>     at build time if doing static builds). That worry could be solved by
>     possibly having a mapserver:: prefix in front of those namespace
>     names
>     (can be done with some #define trickery. See
>     https://github.com/OSGeo/PROJ/blob/9f89c7288e44c64ba234a299b1d5528a54d9d61e/include/proj/util.hpp#L104
>     for potential inspiration)
>     The interesting take-away from my perspective is that the OGR
>     overhead
>     for FlatGeobuf is only 5 ms, but 13 ms for Shapefile. So one
>     interpretation would be that there's some inefficiency in the OGR
>     Shapefile driver vs the native MapServer provider.
>     Even
>     Le 17/05/2022 à 15:19, Jeff McKenna a écrit :
>     > Update: Björn has completed the effort (which now includes several
>     > msautotests) and we've created an RFC (137) for the native
>     FlatGeobuf
>     > support: https://mapserver.org/development/rfc/ms-rfc-137.html
>     > I therefore motion to include FlatGeobuf as a native MapServer
>     driver,
>     > per RFC 137, and maintained by Björn Harrtell.
>     > starting with my +1
>     > Some other interesting updates:
>     > - great to see changes here made through testing benefiting so many
>     > other projects
>     > - here is an updated benchmark result (that is mentioned in the
>     RFC) :
>     >   FlatGeobuf (native) 0.008s
>     >   Shapefile (native)  0.010s
>     >   FlatGeobuf (OGR)    0.013s
>     >   Shapefile (OGR)     0.023s
>     >   GeoPackage (OGR)    0.042s
>     >   SpatiaLite (OGR)    0.045s
>     >   PostGIS (native)    0.053s
>     >   GeoJSON (OGR)       0.089s
>     > (that was with yesterday's main, GDAL 3.4.3, with MS4W on Windows)
>     > - with all this testing done, and the existing FlatGeobuf
>     > documentation effort, it will be very easy to add this to the main
>     > documentation now...
>     > Thanks,
>     > -Björn & Jeff
>     > On 2022-04-27 3:07 p.m., Jeff McKenna wrote:
>     >> Great point Even, here is an updated result:
>     >>    Shapefile       0.011s
>     >>    FlatGeobuf      0.014s
>     >>    Shapefile (OGR) 0.024s
>     >>    GeoPackage      0.042s
>     >>    SpatiaLite      0.045s
>     >>    PostGIS         0.053s
>     >>    GeoJSON         0.089s
>     >> -jeff
>     >> On 2022-04-27 2:09 p.m., Even Rouault wrote:
>     >>> Jeff,
>     >>> as a data point, perhaps you could enhance your bench with
>     >>> shapefiles through OGR ? It would be interesting to have a
>     sense of
>     >>> the OGR overhead (that will be the same for any OGR supported
>     >>> datasource) to have an idea if it is really worth the effort
>     to have
>     >>> a native FlatGeobuf provider for MapServer w.r.t going through
>     OGR
>     >>> (it is hard to beat shapefile, and the current difference between
>     >>> shapefile and flatgeobuf is small)
>     >>> Even
>     >>> Le 26/04/2022 à 12:57, Jeff McKenna a écrit :
>     >>>> (to followup from our chat on IRC yesterday)
>     >>>> To clarify: this would be a new native format in MapServer,
>     such as
>     >>>> Shapefile or PostGIS, and the goal would be to not connect to
>     >>>> FlatGeobuf through OGR, but instead directly, such as:
>     >>>>   DATA countries.fgb
>     >>>> instead of:
>     >>>>   CONNECTIONTYPE OGR
>     >>>>   CONNECTION "countries.fgb"
>     >>>>   DATA "countries"
>     >>>> This should improve the performance even more.  And it will
>     be easy
>     >>>> to update the documentation, as the existing files just need
>     to be
>     >>>> updated (see the new page at
>     >>>> https://mapserver.org/input/vector/flatgeobuf.html )
>     >>>> Great plan Björn!  I look forward to your Pull Request, ha, and
>     >>>> will tackle the documentation changes for you.
>     >>>> This is also great news for MapServer, and will give us some
>     nice
>     >>>> publicity.
>     >>>> Thanks so much!
>     >>>> -jeff
>     >>>> On 2022-04-25 5:57 p.m., Björn Harrtell wrote:
>     >>>>> Hi mapserver devs!
>     >>>>> I got interested in the subject because of the tests made
>     recently
>     >>>>> by Jeff that shows the potential of the format. I believe it
>     >>>>> should be possible to get significant additional performance
>     out
>     >>>>> of FlatGeobuf in MapServer if it was built in just like
>     Shapefile
>     >>>>> support is.
>     >>>>> FlatGeobuf C++ implementation is rather small, doesn't
>     require any
>     >>>>> dependencies, and I don't expect it to require any invasive
>     >>>>> changes to existing code.
>     >>>>> Would love to get started on this ASAP, if there are no
>     >>>>> objections. :)
>     >>>>> Regards,
>     >>>>> Björn Harrtell
>     >> ______
>     > _______________________________________________
>     > MapServer-dev mailing list
>     > MapServer-dev at lists.osgeo.org
>     > https://lists.osgeo.org/mailman/listinfo/mapserver-dev
>     http://www.spatialys.com
>     My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20220518/8e26a778/attachment-0001.htm>
More information about the MapServer-dev mailing list
