[mapserver-dev] MapServer 8.0 Beta Release?
Even Rouault
even.rouault at spatialys.com
Mon May 23 10:15:41 PDT 2022
Jeff,
is there a build log somewhere with the warnings in mapowscommon /
mapjoin ? I can't reproduce that locally with my native Focal
environement. Perhaps a different set of compilation options or
different compiler version.
Even
Le 23/05/2022 à 18:16, Jeff McKenna a écrit :
> Hi all,
> I thought I'd share some interesting updates from my side, for the 8.0
> release:
> - Travis and GitHub build actions have been updated to run on Ubuntu
> Focal (20.04)
> - the builds compile PHPNG MapScript for 7.4.6, 8.0.19, 8.1.6 / Python
> MapScript 3.7.7, 3.8.3, 3.9.0 without any issues
> - msautotests: I've made it down to about 20 broken tests (from about
> 200, yikes)
> - of note, is that the existing flag "-Werror" while compiling
> MapServer (which means break on all warnings, treat warnings as
> errors) does cause issues in several files (mappwscommon.c, majoin.c),
> so the nasty workaround is to set -Wno-stringop-overflow,
> -Wno-format-overflow in the build script, which is not good, meaning
> that these warnings should be fixed and -Werror reset.
> You can follow along or made changes at
> https://github.com/MapServer/MapServer/pull/6430
> I think the upgrade to a more recent Ubuntu for all of our tests was
> critical for the 8.0 release (which is why I put so much darn effort
> in that).
> Hope this looks good to everyone. Exciting,
> -jeff
http://www.spatialys.com
More information about the MapServer-dev
