[mapserver-dev] MapServer 8.0 Beta Release?
Jeff McKenna
jmckenna at gatewaygeomatics.com
Mon May 23 13:00:24 PDT 2022
Thanks so much for these fixes Even, I've removed the workarounds.
-jeff
On 2022-05-23 4:04 p.m., Even Rouault wrote:
> I could actually reproduce them with: cmake -DCMAKE_C_FLAGS="-O2 -Wall
> -Werror -Wextra" -DCMAKE_CXX_FLAGS="-O2 -Wall -Werror -Wextra"
> Some of them are actually serious. Fixes queued in
> https://github.com/MapServer/MapServer/pull/6531
> Once it is merged, you can rebase your branch on top of it and drop your
> workarounds:
> git fetch origin main
> git rebase origin/main
> git push -f your_remote your_branch
> (assuming 'origin' is the name of the remote to the upstream repositoy)
> Le 23/05/2022 à 20:18, Jeff McKenna a écrit :
>> Thanks Even, I saved the 2 errors locally (next time I'll save the log
>> url instead) : https://pastebin.com/4GAiVhLx
>> (yes very difficult to reproduce locally)
>> -jeff
>> On 2022-05-23 2:15 p.m., Even Rouault wrote:
>>> Jeff,
>>> is there a build log somewhere with the warnings in mapowscommon /
>>> mapjoin ? I can't reproduce that locally with my native Focal
>>> environement. Perhaps a different set of compilation options or
>>> different compiler version.
>>> Even
>>> Le 23/05/2022 à 18:16, Jeff McKenna a écrit :
>>>> Hi all,
>>>> I thought I'd share some interesting updates from my side, for the
>>>> 8.0 release:
>>>> - Travis and GitHub build actions have been updated to run on Ubuntu
>>>> Focal (20.04)
>>>> - the builds compile PHPNG MapScript for 7.4.6, 8.0.19, 8.1.6 /
>>>> Python MapScript 3.7.7, 3.8.3, 3.9.0 without any issues
>>>> - msautotests: I've made it down to about 20 broken tests (from
>>>> about 200, yikes)
>>>> - of note, is that the existing flag "-Werror" while compiling
>>>> MapServer (which means break on all warnings, treat warnings as
>>>> errors) does cause issues in several files (mappwscommon.c,
>>>> majoin.c), so the nasty workaround is to set -Wno-stringop-overflow,
>>>> -Wno-format-overflow in the build script, which is not good, meaning
>>>> that these warnings should be fixed and -Werror reset.
>>>> You can follow along or made changes at
>>>> https://github.com/MapServer/MapServer/pull/6430
>>>> I think the upgrade to a more recent Ubuntu for all of our tests was
>>>> critical for the 8.0 release (which is why I put so much darn effort
>>>> in that).
>>>> Hope this looks good to everyone. Exciting,
>>>> -jeff
More information about the MapServer-dev
