[MapServer-dev] mapserver compiling errors
Martin Černý cernym at cesnet.cz
Tue Nov 1 07:13:42 PDT 2022
Hello,
      It helped. It was my misunderstanding of the cmake messages. Thank
you very much.
Regards
Martin
Dne 31. 10. 22 v 16:26 Jeff McKenna napsal(a):
> Exactly what I meant, now focus your efforts on removing those "CMake
> Error" messages in that terminal output, and once you remove those the
> build will work.  (use the HINTS that are given in each section of
> that output, to disable or enable what you need)
> Hope that helps,
> -jeff
Ing. Martin Cerny
CESNET, z.s.p.o.
Zikova 4,
160 00 Praha 6
Czech Republic
Tel:+420-2-34680289
Gsm:+420-606-719014
Type: application/pkcs7-signature
Desc: Elektronicky podpis S/MIME
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20221101/2207f5cd/attachment.bin>
More information about the MapServer-dev mailing list
