[MapServer-dev] SWIG library: call for help with final 4.1.0 release push
Jeff McKenna
jmckenna at gatewaygeomatics.com
Sun Oct 16 04:06:16 PDT 2022
https://sourceforge.net/projects/swig/files/swig/swig-4.1.0-beta1/swig-4.1.0-beta1.tar.gz
-jeff
On 2022-10-16 8:04 a.m., Jeff McKenna wrote:
> Oops he likely meant: swig-4.1.0-beta1
> -jeff
> On 2022-10-16 8:03 a.m., Jeff McKenna wrote:
>> See below for the call to test swig-4.0.0-beta1
>> -jeff
>> On 2022-10-15 1:03 p.m., William S Fulton wrote:
>> > I have finally made a beta version of SWIG 4.1.0 available for testing
>> > before making the official release. I aim to turn this into the
>> official
>> > release on 24 Oct if there are no major issues reported, so please
>> test
>> > it before then and send feedback via the Github issue tracker
>> > <https://github.com/swig/swig/issues> or reply to this email including
>> > the mailing lists.
>> > Download it from here:
>> > Source tarball:
>> > http://prdownloads.sourceforge.net/swig/swig-4.0.0-beta1.tar.gz
>> > <http://prdownloads.sourceforge.net/swig/swig-4.0.0-beta1.tar.gz>
>> > Windows prebuilt executable:
>> > http://prdownloads.sourceforge.net/swig/swigwin-4.1.0-beta1.zip
>> > <http://prdownloads.sourceforge.net/swig/swigwin-4.1.0-beta1.zip>
>> > Summary of changes:
>> > SWIG-4.1.0 summary:
>> > - Add Javascript Node v12-v18 support, remove support prior to v6.
>> > - Octave 6.0 to 6.4 support added.
>> > - Add PHP 8 support.
>> > - PHP wrapping is now done entirely via PHP's C API - no more .php
>> wrapper.
>> > - Perl 5.8.0 is now the oldest version SWIG supports.
>> > - Python 3.3 is now the oldest Python 3 version SWIG supports.
>> > - Python 3.9-3.11 support added.
>> > - Various memory leak fixes in Python generated code.
>> > - Scilab 5.5-6.1 support improved.
>> > - Many improvements for each and every target language.
>> > - Various preprocessor expression handling improvements.
>> > - Improved C99, C++11, C++14, C++17 support. Start adding C++20
>> standard.
>> > - Make SWIG much more move semantics friendly.
>> > - Add C++ std::unique_ptr support.
>> > - Few minor C++ template handling improvements.
>> > - Various C++ using declaration fixes.
>> > - Few fixes for handling Doxygen comments.
>> > - GitHub Actions is now used instead of Travis CI for continuous
>> > integration.
>> > - Add building SWIG using CMake as a secondary build system.
>> > - Update optional SWIG build dependency for regex support from PCRE to
>> > PCRE2.
>> > William
>> On 2022-09-21 9:36 a.m., Jeff McKenna wrote:
>>> A related news item for those MapServer people concerned on when the
>>> next SWIG library release will be: dive in and help here at
>>> https://sourceforge.net/p/swig/mailman/message/37710392/
>>> Side note: I've noticed that MapGuideOS PSC has recently voted to
>>> switch to SWIG support for their PHP modules.
>>> [so SWIG has become another one of those core FOSS4G libraries]
>>> Thanks,
>>> -jeff
More information about the MapServer-dev
