[MapServer-dev] Polygon fill pattern question
Rahkonen Jukka
jukka.rahkonen at maanmittauslaitos.fi
Fri Sep 30 06:10:04 PDT 2022
Have you tried just to create a so wide fill symbol file that the inner symbols would repeat nicely? It seems that you should include about 9 symbols horizontally. I suppose it would work fine with Mapserver but you can have a try with the attached pattern file that is a bit similar to what you would need.
-Jukka Rahkonen-
Lähettäjä: MapServer-dev <mapserver-dev-bounces at lists.osgeo.org> Puolesta Tamas Szekeres
Lähetetty: perjantai 30. syyskuuta 2022 14.25
Vastaanottaja: mapserver-dev at lists.osgeo.org<mailto:mapserver-dev at lists.osgeo.org>
Aihe: [MapServer-dev] Polygon fill pattern question
Dear Devs,
Do anyone have idea how to implement a fill pattern like below in mapserver?
[cid:image001.png at 01D8D4E5.F98434E0]
Notice the small vertical offset between the elements that makes it difficult to use a repeated symbol to implement this.
Thanks,
Tamas
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20220930/a7185989/attachment-0001.htm>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20220930/a7185989/attachment-0001.png>
Type: image/jpeg
Desc: BROWN-CELLS_E1_064_A_RGB.JPG
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20220930/a7185989/attachment-0001.jpe>
More information about the MapServer-dev
