[MapServer-dev] MapServer 8.2 Release Plan
Steve Lime
sdlime at gmail.com
Wed Dec 13 14:03:07 PST 2023
Regarding:
https://github.com/MapServer/MapServer/issues/6907 "Queries that find no
results not returning and error message"
I do have a proposed fix locally and I just need to prepare a pull request.
Been sitting on it for some time now, just limited on time... I did have a
couple of other small adds:
1. https://github.com/MapServer/MapServer/issues/6968
2. Adding some template tag capabilities for pass-through variables,
similar to what's supported for item tags such as pattern matching and
default values.
The first one should be relatively easy and a nice add... Jeff's proposed
schedule seems ok.
--Steve
On Mon, Dec 11, 2023 at 8:22 AM Jeff McKenna via MapServer-dev <
mapserver-dev at lists.osgeo.org> wrote:
> I think the major remaining issue for 8.2 is
> (see Milestone for all issues:
> https://github.com/MapServer/MapServer/milestone/60 )
> -jeff
> On 2023-12-11 10:13 a.m., Jeff McKenna wrote:
> > Hi Seth,
> > I think we should go ahead with the final 8.2.0 release, even without
> > those items you mentioned (as so much effort has been already put into
> > the release, as tracked by that release page that I've been
> > maintaining). I propose the following schedule:
> > - Feature freeze: Fri. January 5, 2024
> > - 8.2-beta: Fri. January 12, 2024
> > - 8.2-rc1: Fri. January 19, 2024
> > - 8.2 (final): Fri. January 26, 2024
> > That would give everyone a few weeks through the holidays to tackle any
> > lingering tasks on their plates.
> > I'll also do a MapCache release then, to help packagers.
> > Thanks, and merry Christmas everyone,
> > -jeff
> > On 2023-12-11 7:08 a.m., Seth G via MapServer-dev wrote:
> >> Hi all,
> >> Looking at the
> >> https://github.com/MapServer/MapServer/wiki/MapServer-8.2-Release-Plan
> >> there are a few outstanding items:
> >> - I'm not sure the MapML support is actively being worked on (it has
> >> been in the last few release plans)?
> >> - Steve - I can take a look at
> >> https://github.com/MapServer/MapServer/issues/6907 unless you already
> >> have an idea how to fix it?
> >> Then the only remaining item is
> >> https://github.com/MapServer/MapServer/issues/6113 (which has been
> >> around since 2020).
> >> I'm presuming at this stage an 8.2 release will be in 2024, and so
> >> should be added to the OSGeo budget request?
> >> Seth
> MapServer-dev mailing list
> MapServer-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20231213/cb5d92ca/attachment.htm>
More information about the MapServer-dev
