[MapServer-dev] Does mapserver support GIF format for WMS / WMTS services?
Even Rouault even.rouault at spatialys.com
Fri Sep 8 05:43:32 PDT 2023
Philippe,
Le 08/09/2023 à 14:16, Philippe Ghesquiere via MapServer-dev a écrit :
> Hi all,
> I am a little bit confused with GIF support for WMS/WMTS services.
> In several parts of the documentation, it is mentioned that GIF
> support is discarded with the end of the "GD library" support.
> I noticed the compilation option in CMakelists.txt :
> option(WITH_GIF "Enable GIF support (for PIXMAP loading)" ON)
> I do not understand the "for PIXMAP loading" comment.
> Anyway, our mapserver does not server WMS/WMTS tiles in GIF format.
> So here are my few questions :
>   * is GIF support enabled by default for WMS/WMTS services ?
no
>   * do I need to add the option : -DWITH_GIF=ON for cmake configuration ?
only to load raster symbols in GIF format
>   * do I need to add a specific mapserver configuration, like :
>     OUTPUTFORMAT
>        NAME "GIF"
>        DRIVER GDAL/GIF
>        MIMETYPE "image/GIF"
>        IMAGEMODE RGB
>        EXTENSION "gif"
>     END
I don't think that will work. The GDAL GIF driver already expects
paletted data, not RGB.  And I don't think switching IMAGEMODE to PC256
would work since that support has effectively gone.
I believe the only option to get paletted data is to use PNG8 with the
AGG/PNG8 driver and MIMETYPE="image/png; mode=8bit"
Even
> Thanks for your help and advices
> Philippe
> The information in this e-mail is confidential. The contents may not
> be disclosed or used by anyone other than the addressee. Access to
> this e-mail by anyone else is unauthorised.
> If you are not the intended recipient, please notify Airbus
> immediately and delete this e-mail.
> Airbus cannot accept any responsibility for the accuracy or
> completeness of this e-mail as it has been sent over public networks.
> If you have any concerns over the content of this message or its
> Accuracy or Integrity, please contact Airbus immediately.
> All outgoing e-mails from Airbus are checked using regularly updated
> virus scanning software but you should take whatever measures you deem
> to be appropriate to ensure that this message and any attachments are
> virus free.
> MapServer-dev mailing list
> MapServer-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20230908/b377903a/attachment.htm>
More information about the MapServer-dev mailing list
