[MapServer-dev] GNU Regex Replacement?
Howard Butler
howard at hobu.co
Fri Jun 7 12:38:28 PDT 2024
I was playing around with getting Conda Forge builds of MapServer working, and when I got to Windows, I realized we need the GNU Regex library
https://github.com/conda-forge/mapserver-feedstock/issues/47#issue-2341018003
It is ancient, not released as a standalone library anymore, and causes anything linking against it to also be GPL (which we're doing in the Windows build situation). Maybe it is not worth the trouble to change anything, but if one were to do so, what should be used in its place?
Howard
More information about the MapServer-dev
