[MapServer-dev] zoomRectangle error image rectangle maxy >= miny
Fernando Sánchez García
i82sagaf at uco.es
Tue May 7 01:25:55 PDT 2024
Dear developers, my name is Fernando and I work at the University of
Córdoba in Spain. First, always thank you for your great work, it is
priceless. I have been using mapserver for several years as a user at
the University together with pmapper. Our old virtual machine has Ubuntu
Server 18.04 LTS + mapserver 7.2.1 + PHP 5.6.40 + postgres/postgis with
pmapper 4.3.2. and locally on my computer I have MS4W 3.2.3 with pmapper
4.3.2. Unfortunately pmapper was discontinued a few years ago and
although I don't have much programming knowledge, I have started trying
to make some small changes to the pmapper code to adapt it to PHP 7/8
(although I know other more up-to-date alternatives such as Openlayers).
I have reached the "Zoom to rectangle" function where Armin implemented
it like this:
* ZOOM&PAN FUNCTIONS
* Zoom to rectangle
protected function pmap_zoomrect()
if (isset($_REQUEST["imgbox"])) {
$imgbox_str = $_REQUEST["imgbox"];
//error_log($imgbox_str);
if ($imgbox_str != "") {
$imgbox_arr = explode(" ", $imgbox_str);
// New map extent in image pixel ((0,0) top-left)
$pix_minx = $imgbox_arr[0];
$pix_miny = $imgbox_arr[1];
$pix_maxx = $imgbox_arr[2];
$pix_maxy = $imgbox_arr[3];
if ($pix_minx == $pix_maxx) $pix_maxx = $pix_maxx + 3;
## increase max extent if min==max
if ($pix_miny == $pix_maxy) $pix_maxy = $pix_maxy - 3; ##
$pixext = ms_newrectObj();
// Modified by Thomas RAFFIN (SIRAP)
// If the rectangle is not in the same proportions as
the map,
// To leave the coeff Y / X unghanged, we need to made
$geoNewCoeff = $geo0Coeff...
$geo0Coeff = $this->mapheight / $this->mapwidth;
$geoNewDeltaX = $pix_maxx - $pix_minx;
$geoNewDeltaY = $pix_maxy - $pix_miny;
$geoNewCoeff = $geoNewDeltaY / $geoNewDeltaX;
if ($geoNewCoeff < $geo0Coeff) {
$newDeltaYCorrected = $geo0Coeff * $geoNewDeltaX;
$newDeltaYToAdd = ($newDeltaYCorrected -
$geoNewDeltaY) / 2;
$pix_miny -= $newDeltaYToAdd;
$pix_maxy += $newDeltaYToAdd;
} else {
$newDeltaXCorrected = $geoNewDeltaY / $geo0Coeff;
$newDeltaXToAdd = ($newDeltaXCorrected -
$geoNewDeltaX) / 2;
$pix_minx -= $newDeltaXToAdd;
$pix_maxx += $newDeltaXToAdd;
$pixext->setExtent($pix_minx,$pix_miny,$pix_maxx,$pix_maxy);
// Zoom to full extent when starting
} else {
$pixext->setExtent(0, 0, $this->mapwidth, $this->mapheight);
$this->map->zoomrectangle($pixext, $this->mapwidth,
$this->mapheight, $this->geoext0);
PMCommon::freeMsObj($pixext);
In this function Mapscript zoomrectangle is called, which according to
the old PHP Mapscript documentation
(https://mapserver.org/mapscript/php/index-5.6.html#mapobj) is like this:
void zoomrectangle(rectObj oPixelExt, int nImageWidth, int nImageHeight,
rectObj oGeorefExt)
Set the map extents to a given extents.
Parameters are :
oPixelExt (rect object) : Pixel Extents, with (0,0) at the
top-left The rectangle contains the coordinates of the LL and UR
coordinates in pixel. (the maxy in the rect object should be < miny value)
------- UR (values in the rect object : maxx, maxy)
LL (values in the rectobject minx, miny)
Width : width in pixel of the current image.
Height : Height in pixel of the current image.
Georef extent (rectObj) : current georef extents.
The pmapper log file shows me the following values when I zoom without
any problem and the result is satisfactory, that is, it zooms in on my
map correctly:
P.MAPPER debug info en la función pmap_zoomrect de map.php
$pix_minx 551.97186827847
$pix_miny 86.08332824707031
$pix_maxx 632.19478821567
$pix_maxy 120.08332824707031
$this->geoext0->minx -334.31761006289
$this->geoext0->miny -22
$this->geoext0->maxx 525.31761006289
$this->geoext0->maxy 342
My .map file has the following EXTENT -37 -22 228 334 and "wms_srs"
"epsg:3857".
I have updated to MS4W 4.0.4 which has MapServer and MapScript
7.7.0-dev, PHP to 7.2.31 and SWIG support. According to the current SWIG
MapScript API Reference:
mapscript.mapObj
class mapscript.mapObj(*args)
Methods:
zoomRectangle(poPixRect: rectObj, width: int, height: int, poGeorefExt:
rectObj, poMaxGeorefExt: rectObj) → int[source]
Set the map extents to a given extents. Returns MS_SUCCESS or
MS_FAILURE on error
and I have adapted the code like this:
* Zoom to rectangle
pm_logDebug(3, $imgbox_str, "\$imgbox_str en la función
pmap_zoomrect de map.php");
// 642.0833282470703 40.08332824707031 685.0833282470703
68.08332824707031
// BEFORE:
// $pixext = ms_newrectObj();
the map,
$geoNewDeltaY) / 2;
} else {
$geoNewDeltaX) / 2;
// BEFORE:
// NEW:
$pixext = new rectObj($pix_minx, $pix_miny, $pix_maxx,
$pix_maxy);
} else {
// BEFORE:
// $this->map->zoomrectangle($pixext, $this->mapwidth,
// NEW:
$maxGeoExt = null; // Null o tu valor predeterminado para la
extensión geográfica máxima
$this->map->zoomRectangle($pixext, $this->mapwidth,
$this->mapheight, $this->geoext0, $maxGeoExt);
but the following error is returned:
[06-May-2024 12:49:32 Europe/Paris] PHP Fatal error: Uncaught
Exception: mapscript::mapObj::zoomRectangle(): General error message.
image rectangle maxy >= miny in
C:\ms4w\apps\sig-uco\htdocs\phpmapscriptng-swig\include\mapscript.php:2908
Stack trace:
#0
C:\ms4w\apps\sig-uco\htdocs\phpmapscriptng-swig\include\mapscript.php(2908):
mapobj_zoomrectangle(Resource id #10, Object(rectObj), '1503.166666',
'351.16666599999...', Object(rectObj), NULL)
#1
C:\ms4w\apps\sig-uco\htdocs\pmapper\pmapper-4.3.2\incphp\map\map.php(629):
mapObj->zoomRectangle(Object(rectObj), '1503.166666',
#2
C:\ms4w\apps\sig-uco\htdocs\pmapper\pmapper-4.3.2\incphp\map\map.php(489):
PMap->pmap_zoomrect()
#3
C:\ms4w\apps\sig-uco\htdocs\pmapper\pmapper-4.3.2\incphp\map\map.php(74):
PMap->pmap_createMap()
#4
C:\ms4w\apps\sig-uco\htdocs\pmapper\pmapper-4.3.2\incphp\xajax\x_load.php(78):
PMap->pmap_create()
#5 {main}
thrown in
C:\ms4w\apps\sig-uco\htdocs\phpmapscriptng-swig\include\mapscript.php on
line 2908
I have also updated to MS4W 5.0.0 which has MapServer and MapScript
8.2.0-dev and PHP to 8.2.11 and the error is the same.
How should I solve the problem? Thanks.
More information about the MapServer-dev
