[MapServer-dev] ogcapi.cpp 404 on https://raw.githubusercontent.com/opengeospatial/ogcapi-processes/master/core/openapi/schemas/exception.yaml
Gérald Fenoy
gerald.fenoy at geolabs.fr
Tue Apr 15 01:57:24 PDT 2025
You can also use the official schemas directory below:
https://schemas.opengis.net/ogcapi/common/part1/1.0/openapi/schemas/exception.yaml
Best regards
Gérald Fenoy
> Le 15 avr. 2025 à 10:35, Sebastiaan Couwenberg via MapServer-dev <mapserver-dev at lists.osgeo.org> a écrit :
> On 4/15/25 9:06 AM, Willem Jenniskens via MapServer-dev wrote:
>> In mapogcapi.cpp this url is present:
>> It gives 404. I think it should be:
>> https://raw.githubusercontent.com/opengeospatial/ogcapi-processes/master/openapi/schemas/common-core/exception.yaml
>> or
>> https://raw.githubusercontent.com/opengeospatial/ogcapi-processes/refs/heads/master/openapi/schemas/common-core/exception.yaml
>> Do you agree? What is the best way to do this?
> Using one of the tags should be a more stable ref than master, e.g.:
> https://raw.githubusercontent.com/opengeospatial/ogcapi-processes/refs/tags/1.0-draft.6/core/openapi/schemas/exception.yaml
> A specific commit should also be stable:
> https://raw.githubusercontent.com/opengeospatial/ogcapi-processes/6f4945ed158fa064bb75a0f11d24c8f683f2fb6b/core/openapi/schemas/exception.yaml
> Kind Regards,
> Bas
> GPG Key ID: 4096R/6750F10AE88D4AF1
> Fingerprint: 8182 DE41 7056 408D 6146 50D1 6750 F10A E88D 4AF1
> MapServer-dev mailing list
> MapServer-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
More information about the MapServer-dev
