[MapServer-dev] Remove requirement for TEMPLATE keyword?
Even Rouault
even.rouault at spatialys.com
Sun Jan 26 09:44:44 PST 2025
Seth,
I've also always been perplexed by the implicit use of template to mean
queryable. Maybe we need a QUERYABLE ON keyword ?
Even
Le 26/01/2025 à 09:47, Seth G via MapServer-dev a écrit :
> Hi devs,
> One of the issues I've run into when explaining MapServer to colleagues is the TEMPLATE keyword. The docs don't really explain its purpose, or mention how it makes a layer "queryable" [1]. I also ran into myself this week when a layer wasn't displaying in the OGC Features API as I forgot to add TEMPLATE to the LAYER definition.
> Should dropping the requirement to add a TEMPLATE to a LAYER to make it queryable be considered in a future release?
> There are more and more examples of the following, which is hard to explain to new users:
> LAYER
> TEMPLATE "ttt"
> # or
> # TEMPLATE VOID
> There are also many cases in the codebase where this is set automatically anyway:
> layer->template = msStrdup("ttt");
> The only problem I can see is that it could accidentally allow feature attributes to "leak" out, e.g. for LAYERs with a "select * from tbl", but there is a prevalence of examples when TEMPLATE is set to a fake value anyway.
> Are there any other side-effects if it were set to be "on" by default?
> Seth
> [1] https://mapserver.org/mapfile/layer.html#mapfile-layer-template
> web:https://geographika.net & https://mapserverstudio.net
> mastodon: @geographika at mastodon.social
> MapServer-dev mailing list
> MapServer-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
http://www.spatialys.com
"De l'égo à l'égoût, il n'y a qu'une bouche mal refermée", André Isaac
More information about the MapServer-dev
