[MapServer-dev] Remove requirement for TEMPLATE keyword?
Even Rouault even.rouault at spatialys.com
Mon Jan 27 05:06:37 PST 2025
Le 27/01/2025 à 13:34, Seth G via MapServer-dev a écrit :
> Thanks Even and Jukka for the feedback,
> I'd be a bit hesitant about adding a new keyword QUERYABLE as this would require updating a lot of existing Mapfiles.
We could make it such that setting TEMPLATE still implies QUERYABLE ON
if it the later is not set in the 8.x series (with some deprecation
warning that in MapServer 9 QUERYABLE should be set?)
http://www.spatialys.com
"De l'égo à l'égoût, il n'y a qu'une bouche mal refermée", André Isaac
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20250127/4e52a107/attachment.htm>
More information about the MapServer-dev mailing list
