[MapServer-dev] //www.mapserver.org/lib/OpenLayers-ms60.js
Seth G sethg at geographika.co.uk
Wed Jan 29 12:59:14 PST 2025
Thanks Jeff.
Strangely, https://www.mapserver.org/lib/ still has the subfolders img/ and theme/ which have been untouched since 2014, so it seems like just the JS file was removed rather than anything related to the docs deploy.
>From whois checks, I gathered the following:
- Docs are deployed to https://mapserver.github.io (185.199.108.153) from the repo at https://github.com/MapServer/mapserver.github.io. https://www.mapserver.org/ points to this website.
- mapserver.org and the /lib folder is hosted on an osgeo server: 140.211.15.3 (osgeo6.osgeo.osuosl.org)
So I'm guessing there must be some redirects somewhere. Any idea if this is documented?
+1 on having the /lib folder (and subfolders) added to the docs repo, and would make it easier to add new OL versions in the future.
Seth
web:https://geographika.net & https://mapserverstudio.net
mastodon: @geographika at mastodon.social
On Wed, Jan 29, 2025, at 5:31 PM, Jeff McKenna via MapServer-dev wrote:
> It looks like it was pruned on deployment indeed.  It is now visible at
> https://www.mapserver.org/lib/OpenLayers-ms60.js
> However I like the idea of storing/deploying it in the docs repo, will
> do that this afternoon.
> -jeff
> Jeff McKenna
> GatewayGeo: Developers of MS4W, & offering MapServer Consulting/Dev
> co-founder of FOSS4G
> http://gatewaygeo.com/
> On 2025-01-29 5:58 a.m., Seth G via MapServer-dev wrote:
>> Hi,
>> The OpenLayers 2.10 file at //www.mapserver.org/lib/OpenLayers-ms60.js has been removed from the server.
>> This is hardcoded in the codebase and used by https://mapserver.org/cgi/openlayers.html
>> Does anyone know if this is wiped-out when deploying the docs? If so, maybe it can be added to the docs repository and deployed with the docs. I don't have access to the server, so I'm not sure how the /lib folder is created.
>> I'm hoping to update the OpenLayers viewer to v10 this year, so at some point will update the version.
>> Seth
> MapServer-dev mailing list
> MapServer-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
More information about the MapServer-dev mailing list
