[MapServer-dev] Using OGR geoparquet data in mapserver - no spatial filtering
Michael Smith michael.smith.erdc at gmail.com
Fri Jul 18 04:03:46 PDT 2025
All,
Anyone know a current way to get mapserver to add spatial filtering on OGR geoparquet layers. Have been unable to get the actual sql query being used with CPL_DEBUG inside mapserver with CONFIG "CPL_DEBUG" "ON" but from the performance, it appears no spatial filtering is being done. I suspect code changes to mapogr would be needed to do this but wondering if anyone else has looked into this.
Also, I tried using ADBC connection to parquet, and while it worked (technically) it really used an excessive amount of CPU and memory over using the geoparquet driver.
Mike
Michael Smith
RSGIS Center – ERDC CRREL NH
US Army Corps
More information about the MapServer-dev mailing list
