[MapServer-dev] Test failures in CI
Michael Smith
michael.smith.erdc at gmail.com
Fri Nov 7 03:22:39 PST 2025
I’m seeing these test failures in CI https://github.com/MapServer/MapServer/pull/7379 for the Address Sanitizer and Regular, with Coverage actions
FAILED run_test.py::test[wcs_netcdf_3d_input_output_wcs_netcdf_3d_input_output_nc]
FAILED run_test.py::test[wcs_netcdf_3d_output_wcs_netcdf_3d_output_nc] - Asse...
FAILED run_test.py::test[wcs_netcdf_input_output_wcs_netcdf_input_output_wcs10_get_coverage_nc]
FAILED run_test.py::test[wcs_netcdf_input_output_wcs_netcdf_input_output_wcs20_get_coverage_nc]
But nothing in my PR (just adding a space in the oraclespatial function) should affect these netcdf tests at all. Do you know if there is something else going on with these tests?
Mike
Michael Smith
RSGIS Center – ERDC CRREL NH
US Army Corps
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20251107/a7b0ab26/attachment-0001.htm>
More information about the MapServer-dev
