[MapServer-dev] More precise WMS GetFeatureInfo for point symbols: ask for opinions
Even Rouault even.rouault at spatialys.com
Mon Sep 8 05:36:20 PDT 2025
In https://github.com/MapServer/MapServer/pull/7318 I've introduced an
enhancement to be able to identify with WMS GetFeatureInfo point
features through their symbols, rather than just a square centered
around their position. This helps for symbols that are not centered
(offset), or whose shape is not square.
I've extende MapServer syntax to be able to enable that mode, and
configure how it works. If you read the PR, you'll see there is a bit of
a debate on how to best express that conffiguration. Either through a
new IDENTIFICATION block as a child of a LAYER block, or using
PROCESSION directive or wms_ METADATA items. Are there thoughts about that?
Thanks,
Even
http://www.spatialys.com
More information about the MapServer-dev mailing list
