[MapServer-dev] Updating OGC Features API templates
Steve Lime
sdlime at gmail.com
Mon Sep 8 14:03:48 PDT 2025
I guess I'd favor saying html-bootstrap contains templates relative to the
current major version of bootstrap but then I'd keep the older, version
specific, ones as part of the repo. Maybe they don't get installed and are
just there for reference - or a user could install by hand. The drag is
that one needs to keep pace with Bootstrap releases. So, for now
html-bootstrap would contain Bootstrap 5 templates and when version 6 comes
out you'd create a html-bootstrap5 directory that wouldn't get installed
and html-bootstrap would contain Bootstrap 6 files.
On Mon, Sep 8, 2025 at 12:46 PM Seth G via MapServer-dev <
mapserver-dev at lists.osgeo.org> wrote:
> Hi devs,
> I have made updated HTML templates for the OGC Features API in
> https://github.com/MapServer/MapServer/pull/7338 using Bootstrap 5.
> I've added these to a new html-bootstrap5 folder, but maybe it is better
> to replace the current files in the html-bootstrap4 folder and rename it
> html-bootstrap (so it is not tied to a specific version)?
> Advantages of this approach are fewer files to deploy, and users get
> updated templates when updating MapServer versions.
> Disadvantages are users who have set OGCAPI_HTML_TEMPLATE_DIRECTORY to the
> html-bootstrap4 folder will need to update their CONFIG files and users may
> also prefer to keep older versions of templates (although then can save a
> copy locally).
> My preference is to replace, and rename the folder html-bootstrap.
> There are also plans to make installing the templates optional - see
> https://github.com/MapServer/MapServer/pull/7309
> Thoughts and comments welcome,
> Seth
> web:https://geographika.net & https://mapserverstudio.net
> mastodon: @geographika at mastodon.social
> MapServer-dev mailing list
> MapServer-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20250908/074ad0f8/attachment.htm>
More information about the MapServer-dev
