[MapServer-dev] More precise WMS GetFeatureInfo for point symbols: ask for opinions
Lime, Steve D (MNIT) steve.lime at state.mn.us
Mon Sep 8 14:48:16 PDT 2025
Ok, cool – then moving the TOLERANCE* parameters inside the new directive makes more sense. Note, I like IDENTIFY more than IDENTIFICATION but that’s just semantics. Would layer-level TOLERANCE* values continue to work, at least for a bit?
From: MapServer-dev <mapserver-dev-bounces at lists.osgeo.org> On Behalf Of Even Rouault via MapServer-dev
Sent: Monday, September 8, 2025 4:28 PM
To: Steve Lime <sdlime at gmail.com>
Cc: MapServer Dev Mailing List <mapserver-dev at lists.osgeo.org>
Subject: Re: [MapServer-dev] More precise WMS GetFeatureInfo for point symbols: ask for opinions
This message may be from an external email source.
Do not select links or open attachments unless verified. Report all suspicious emails to Minnesota IT Services Security Operations Center.
Le 08/09/2025 à 23:13, Steve Lime a écrit :
I could also see this enhancement being useful for native point-based queries too (e.g. mode=query or mode=nquery).
I guess they could be enhanced to use that functionality.  The would need to populate the new query->getFeatureInfo->x_pixel and query->getFeatureInfo->y_pixel fields, so a new X_PIXEL and Y_PIXEL variable should be added
If that's feasible, then I wouldn't tie the configuration to WMS explicitly. What about just using TOLERANCE AUTO? I mean, it seems that this is trying to address the limitations of that configuration parameter.
This isn't exclusive of the TOLERANCE value. The TOLERANCE value can be used to add an extra buffer around the filled areas of the symbol
so you can have something like:
IDENTIFICATION
        TOLERANCE 5
        CLASSAUTO
END
On Mon, Sep 8, 2025 at 7:36 AM Even Rouault via MapServer-dev <mapserver-dev at lists.osgeo.org<mailto:mapserver-dev at lists.osgeo.org>> wrote:
In https://github.com/MapServer/MapServer/pull/7318 I've introduced an
enhancement to be able to identify with WMS GetFeatureInfo point
features through their symbols, rather than just a square centered
around their position. This helps for symbols that are not centered
(offset), or whose shape is not square.
I've extende MapServer syntax to be able to enable that mode, and
configure how it works. If you read the PR, you'll see there is a bit of
a debate on how to best express that conffiguration. Either through a
new IDENTIFICATION block as a child of a LAYER block, or using
PROCESSION directive or wms_ METADATA items. Are there thoughts about that?
Thanks,
Even
http://www.spatialys.com<http://www.spatialys.com/>
MapServer-dev mailing list
MapServer-dev at lists.osgeo.org<mailto:MapServer-dev at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20250908/977faae9/attachment-0001.htm>
More information about the MapServer-dev mailing list
