[MapServer-dev] Proposal of a new MS_ONLINERESOURCE variable
Daniel Morissette
dmorissette at mapgears.com
Sun Feb 8 16:27:01 PST 2026
+1
Daniel
On 2026-02-06 12:53, Seth G via MapServer-dev wrote:
> Hi all,
> One of the pain-points of MapServer deployments are setting the "ows_getcapabilities" for each Mapfile for each
> environment.
> I wrote an RFC athttps://github.com/MapServer/MapServer-documentation/pull/1059 that allows you to set this once for all Mapfiles in a deployment in the CONFIG file.
> After going through the code, it is actually a minimal change to msBuildOnlineResource that could have been a simple pull-request. However I had enough notes to add to the RFC, and thought it would be good to get feedback on the MS_ONLINERESOURCE name and approach.
> I'll start with my +1.
> Seth
> web:https://geographika.net &https://mapserverstudio.net
> mastodon: @geographika at mastodon.social
> MapServer-dev mailing list
> MapServer-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
Daniel Morissette
Mapgears Inc
T: +1 418-696-5056 #201
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20260208/eb14cd95/attachment.htm>
More information about the MapServer-dev
