[MapServer-dev] LLM tool policy for MapServer?
Seth G sethg at geographika.co.uk
Tue Jun 23 00:25:44 PDT 2026
Hi Even, all,
+1 on using the GDAL policy (with the updates from Steve). I also think we should allow LLMs to be used to review code in a PR which I'm not sure is covered in:
"LLMs may only be used as an improved auto-completion mechanism, or for repeated tasks (mechanical refactoring) that could potentially be completed with a deterministic algorithm."
In the case of https://github.com/MapServer/MapServer/pull/7535 I think this could be acceptable under the new policy? The author has declared use of AI, responded to questions, and knows enough about the code they are adding to create a real-world example and documentation. Having said that I don't know anything about the algorithm, and I'm not able to scan through the C code and tell if it is nonsense or not. I'm happy to test the PR locally though.
I think we should continue to encourage MapServer users / power-users to contribute, whilst closing any drive-by LLM PRs, or PRs from "entities" with no interest or connection to the project.
Seth
web:https://geographika.net & https://mapserverstudio.net
mastodon: @geographika at mastodon.social
On Mon, Jun 22, 2026, at 2:09 AM, Even Rouault via MapServer-dev wrote:
> Hi,
> It would have been surprised if we'd have been spared by that plague.
> See https://github.com/MapServer/MapServer/pull/7535
> Adopt https://gdal.org/en/stable/community/ai_tool_policy.html with
> s/GDAL/MapServer and minus the Mitigation paragraph since we don't have
> project-wide funding vehicle ?
> Even
> http://www.spatialys.com
> My software is free, but my time generally not.
> LLMs contribute to global warming and brain rot
> MapServer-dev mailing list
> MapServer-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-dev
More information about the MapServer-dev mailing list
