[MapServer-dev] Rendering Openstreetmap data in Mapserver
Tamas Szekeres szekerest at gmail.com
Thu Mar 5 12:32:28 PST 2026
Hi Devs,
I'm trying to create a vector based map for the openstreetmap data in
Mapserver by utilizing the mapnik styles provided by the openstreetmap-carto
<https://github.com/openstreetmap-carto/openstreetmap-carto> project. So
far, I could achieve a very good result and the map looks is very similar
to the online OSM at all scales, however the only thing I cannot replicate
is the concept of the *[way_pixels]* attribute conditions, where the
feature’s area in pixels at the current map scale should be the part of the
class expressions. I don't see such an option in Mapserver as it stands
now, but supporting the already existing *[map_cellsize] *would be a very
close solution I think, however that is only implemented for the
GEOMTRANSFORM expressions actually.
For example the mapnik style expression
[way_pixels] > 750
could be provided in a MapServer CLASS expression as somehing like:
[way_area] > 750 * [map_cellsize] * [map_cellsize]
Would that be reasonable to implement *[map_cellsize]* in the CLASS
expressions?
Best regards,
Tamas
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20260305/9b4c9bcb/attachment.htm>
More information about the MapServer-dev mailing list
