[MapServer-dev] Rendering Openstreetmap data in Mapserver
Tamas Szekeres szekerest at gmail.com
Thu Mar 5 15:15:09 PST 2026
yes, but I'd prefer just to use:
p.dblval = layer->map->cellsize;
instead of the way we use in GEOMTRANSFORM
p.dblval = map->cellsize * (msInchesPerUnit(map->units, 0) /
                                msInchesPerUnit(layer->units, 0));
because we are talking about "map_cellsize" and not "layer_cellsize"
Lime, Steve D (MNIT) <steve.lime at state.mn.us> ezt írta (időpont: 2026.
márc. 6., P, 0:10):
> Yeah, I saw those sections. I didn’t think we can just set p.dblval in the
> way the geomtransform code does – or maybe it is that simple - easy enough
> to test.
> *From:* Tamas Szekeres <szekerest at gmail.com>
> *Sent:* Thursday, March 5, 2026 5:00 PM
> *To:* Lime, Steve D (MNIT) <steve.lime at state.mn.us>
> *Cc:* mapserver-dev at lists.osgeo.org
> *Subject:* Re: [MapServer-dev] Rendering Openstreetmap data in Mapserver
> In my understanding, the actual value should be provided somewhere here:
> https://github.com/MapServer/MapServer/blob/89d81cb8d0fcf5d44e043d53afe70f6e6a785756/src/maputil.c#L713
> in a similar way as the geomtransform code:
> https://github.com/MapServer/MapServer/blob/89d81cb8d0fcf5d44e043d53afe70f6e6a785756/src/mapgeomtransform.c#L283
> Best regards,
> Tamas
> márc. 5., Cs, 23:17):
> Hmmm… I think this should be possible but I’m not sure exactly what would
> need to change. The expression parser code is not particularly
> straightforward. The map_cellsize token is generally recognized in the
> parser – so not limited to GEOMTRANSFORM but it’s not clear how it gets its
> value.
> *From:* MapServer-dev <mapserver-dev-bounces at lists.osgeo.org> *On Behalf
> Of *Tamas Szekeres via MapServer-dev
> *Sent:* Thursday, March 5, 2026 2:32 PM
> *To:* mapserver-dev at lists.osgeo.org
> *Subject:* [MapServer-dev] Rendering Openstreetmap data in Mapserver
> Hi Devs,
> I'm trying to create a vector based map for the openstreetmap data in
> Mapserver by utilizing the mapnik styles provided by the
> openstreetmap-carto
> <https://github.com/openstreetmap-carto/openstreetmap-carto> project. So
> far, I could achieve a very good result and the map looks is very similar
> to the online OSM at all scales, however the only thing I cannot replicate
> is the concept of the *[way_pixels]* attribute conditions, where the
> feature’s area in pixels at the current map scale should be the part of the
> class expressions. I don't see such an option in Mapserver as it stands
> now, but supporting the already existing *[map_cellsize] *would be a very
> close solution I think, however that is only implemented for the
> GEOMTRANSFORM expressions actually.
> For example the mapnik style expression
> [way_pixels] > 750
> could be provided in a MapServer CLASS expression as somehing like:
> [way_area] > 750 * [map_cellsize] * [map_cellsize]
> Would that be reasonable to implement *[map_cellsize]* in the CLASS
> expressions?
> Best regards,
> Tamas
URL: <http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20260306/958b198a/attachment.htm>
More information about the MapServer-dev mailing list
