[Mapserver-inspire] INSPIRE View Services (Version 3.0)
Implementation Requirement 36
Passmore, James H.
jpass at bgs.ac.uk
Mon Apr 4 11:16:53 EDT 2011
This Layer metadata element shall be mapped to the <wms:BoundingBox> element.
The minimum bounding rectangle of the area covered by the Layer in all supported CRS shall be given.
As far as I know, this isn't configurable using a map file. Can you use mapscript to insert the relevant BoundingBox elements? If so can you give me some hints on how to do this (my knowledge of mapscript is fairly basic).
thanks
James
James Passmore
GIS and WWW Specialist
Information Systems and Infrastructure,
British Geological Survey,
http://www.bgs.ac.uk/
+44 (0)115 936 3125
This message (and any attachments) is for the recipient only NERC
is subject to the Freedom of Information Act 2000 and the contents
of this email and any reply you make may be disclosed by NERC unless
it is exempt from release under the Act. Any material supplied to
NERC may be stored in an electronic records management system.
More information about the Mapserver-inspire
