[Mapserver-inspire] Advertizing the INSPIRE default style
(Implementation Requirement 42)
Guillaume Sueur
no-reply at neogeo-online.net
Fri Apr 15 04:03:51 EDT 2011
Completely, yes. Usage of CLASSGROUP is the way to have a style named
correctly. It becomes a little bit more complicated with the
multilingual requirement.
Thus, the lack of style:title declaration in MapServer is a failure too.
Regards
Guillaume
Le 14/04/2011 17:16, Passmore, James H. a écrit :
> Hi Bart,
> I may have misread this, but as far as I can work out the requirement is that the default style should be called "inspire_common:DEFAULT". As I am only providing one style for each layer I just have to rename it.
> Therefore I just need to set: CLASSGROUP "inspire_common:DEFAULT" in each layer of the map file, and then in each LAYER CLASS add a GROUP "inspire_common:DEFAULT" value
> e.g.
> CLASSITEM "Lith_1"
> CLASS
> NAME "Mudstone"
> EXPRESSION "urn:cgi:classifier:CGI:SimpleLithology:201001:clastic_mudstone"
> COLOR 178 140 89
> END
> CLASS
> NAME "Sandstone"
> EXPRESSION "urn:cgi:classifier:CGI:SimpleLithology:201001:clastic_sandstone"
> COLOR 242 218 121
> END
> CLASS
> NAME "Clay"
> EXPRESSION "urn:cgi:classifier:CGI:SimpleLithology:201001:clay"
> COLOR 250 242 191
> END
> In my newly updated service this gives me:
> <Style>
> <Name>inspire_common:DEFAULT</Name>
> <Title>inspire_common:DEFAULT</Title>
> <LegendURL width="280" height="828">
> <Format>image/png</Format>
> <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple"
> xlink:href="http://ogc.bgs.ac.uk/BGS_Bedrock_and_Surface_Geology/wms.php?version=1.3.0&service=WMS&request=GetLegendGraphic&sld_version=1.1.0&layer=BGS.1M.surface.GeologicUnit&format=image/png&STYLE=inspire_common:DEFAULT"
> </LegendURL>
> </Style>
> Is this your understanding of the requirement?
> James
More information about the Mapserver-inspire
