Projections and debugging web processes
Cameron Shorter
cshorter at optusnet.com.au
Mon Aug 23 23:40:19 PDT 1999
Thankyou Rob,
Changed units to meters and the projection worked!
Cameron.
Rob Atkinson wrote:
> Suggestion:
> try
> UNITS METERS
> rob
> Cameron Shorter wrote:
> > I belive I have worked out how to debug mapserv.cgi. I set up
> > environment variables and then run from the command line, and hence can
> > attach the gdb debugger. Ie, in my .bashrc I set the following:
> > # Env variables for debugging mapserv
> > QUERY_STRING="map=%2Fhome%2Fbikeast%2Fcamerons%2Fbikeast_amg56.map&layer=onroad"
> > REQUEST_METHOD="GET"
> > export QUERY_STRING REQUEST_METHOD
> > My files are in lat/long coordinates and I want to convert them to
> > AMG56.
> > The mapfile works if I comment out all the projection data.
> > I have been using gdb to try and debug mapserv.cgi and compare it to
> > shp2gif. The problem seems to be in msAdjustExtent, but I haven't
> > worked it out yet. I will be doing more work on it over the next few
> > days (if you cannot give me a few hints in the meantime).
> > The mapfile I'm using is below:
More information about the MapServer-users
