Error logging
imap at chesapeake.net
Wed Jul 14 20:59:33 EDT 1999
An idx file is an index files created with "shpindex". If a .idx
existing for a given shapefile layer, mapserv will try to make use
of it. If it is having problems with the .idx file, just delete it.
The "shpindex" seems to work okay on big endian machines and Linux,
but for some reason... not for NT.
-Chris
Cameron Shorter wrote:
> Hi,
> Still going with my installation / debugging.
> Using shp2gif and gdb I discovered that one of my directories was set up
> incorrectly.
> I'm wondering, is there a way to enable to messages that are created by
> msSetError to be put into the logs?
> If not, I'm prepared to code it up. What is the procedure for adding to
> the code base?
> PS. I'm now getting an error message refering to a .idx file. What is a
> .idx file?
> Cameron Shorter
> 61.2.9901-1596 work.
