more 3.3...
Stephen Lime
steve.lime at dnr.state.mn.us
Mon Nov 15 17:19:25 EST 1999
Another version, same place. This one fixes an obscure bug with drawing
raster GIF images. A class color of -1 is now valid for shade and marker symbols
if you have an outlinecolor defined. Since lines don't use outlines a color of -1
causes the line not to be drawn.
Will have a mapscript example up this evening that draws earthquakes pulled
from the USGS quake finger servers in real-time. The current 3.3 alpha release
contains the version of mapscript used to build the demo. In case anyone is
wondering, to build mapscript on a UNIX host:
cd mapscript
(if using proj.4 you'll have to edit Makefile.PL and add include and lib paths for proj)
perl Makfile.PL
make
make install
Depending on your setup you may need to install mapscript as root.
Steve
Stephen Lime
Internet Applications Analyst
Minnesota DNR
500 Lafayette Road
St. Paul, MN 55155
651-297-2937
