mapserver and database connectivity.
    Paul G. Allen
    pgallen at randomlogic.com
    Thu Oct  7 17:57:18 PDT 1999
Stephen Lime wrote:
> I'm wrapping mapserver with SWIG now. Going ok, SWIG ain't perfect but most things I want to do should work. The perl interface allows you to define arbitrary features (points, lines and polygons) and add them to a map composition. This way just about any data source that's accessible from perl can be added to the mapserv.
> Should be doable from PHP as well although I'm not sure if there is a convientent tool like SWIG for extending it. I actually had a PHP module working a few years ago so I know it can be done.
> I don't think extending the C codebase is the way to go unless there's a decent library out there. Too much reinventing the wheel otherwise.
I'm very interested in this as it seems it would apply directly to what we want to do - insert GPS data points into a map. I could do this now by simply converting the data into data sets that mapserver can read and simply reading that data, but if there's another, easier method...
I know nothing about SWIG, not even what it stands for, but I am learning perl. With that, what is SWIG? (Scientific Wild Insane Guess?! :)
PGA
More information about the MapServer-users
