US Street Map (fwd)
Paul G. Allen
pgallen at randomlogic.com
Fri Oct 8 18:21:39 EDT 1999
Scott Phillips wrote:
> Paul,
> There is an converter for windows that costs about $100.00 called TGR2SHP.
> I used it to convert the State of California set to shape files and it
> worked great. It lets you do the conversions straight from the .ZIP files
> and you can do them in batch. See http://www.gistools.com if you want
> more info.
This will do the trick but is there a UNIX/Linux equivalent. (I prefer UNIX/Linux over
the alternative, but I can use TGR2SHP if I must).
Thanks,
PGA
