demo problem
Ma
marin at here.is
Sun Apr 23 04:43:46 EDT 2000
I think you have to use IMAGEPATH and IMAGEURL in your web interface definition in the map
file. For example:
# Start of web interface definition
WEB
IMAGEPATH /home/www/tmp/
IMAGEURL "/tmp/"
HEADER demo_header.html
TEMPLATE demo.html
MINSCALE 1000
MAXSCALE 1550000
END
# end
Ma
sara yurman wrote:
> I've just installed mapserv 3.3.010, and have been trying to make the
> files generate, but don't come up. Unlike the online demo, they
> generate in the ms_demo directory rather than the /tmp directory. I was
> trying to just display a county outline for starters. At times, I've
> turned the logging function on, and it runs frustratingly clean. My
> Apache error log, however, shows the following:
> script not found or unable to stat:
> /home/httpd/cgi-bin/DEMO956440138790.gif
> /home/httpd/cgi-bin/DEMOsb956441272848.gif
> /home/httpd/cgi-bin/DEMOleg956441272848.gif
> /home/httpd/cgi-bin/DEMOref956441272848.gif
> The extents were derived using shpinfo.pl in the
> ../mapscript/perl/examples directory. I changed the units to DD
> (decimal degrees) to match the shape file.
> I've listed the following below:
> * the forms section of my demo_init.html
> * my demo.map file
> * my demo.html file
> I am running Mandrake Linux 6.1 on an intel box, with a 2.2.14 kernel,
> using Apache 1.3.9. and Perl 5.6.0.
> Many thanks for your help.
> Cheers,
> Sara
> ********************Forms section, demo_init.html
> <form method=GET action="/cgi-bin/mapserv">
> <input type="hidden" name="map"
> value="/home/httpd/html/ms_demo/demo.map">
> <input type="hidden" name="layer" value="county">
> <input type="hidden" name="zoomsize" value=2>
> <center><input type="submit" value="Initialize"></center>
> </form>
> ********************demo.map
> # Start of map file
> NAME DEMO
> STATUS ON
> SIZE 600 600
> SHADESET /home/httpd/html/ms_demo/symbols/shade.sym
> MARKERSET /home/httpd/html/ms_demo/symbols/marker.sym
> LINESET symbols/line.sym
> EXTENT -81.456505 35.148420 -80.922882 35.419616
> UNITS DD
> SHAPEPATH "/home/httpd/html/ms_demo/data"
> IMAGECOLOR 255 255 255
> WEB
> TEMPLATE demo.html
> MINSCALE 1000
> MAXSCALE 1550000
> END
> # Start of reference map
> #REFERENCE
> # IMAGE graphics/reference_base.gif
> # EXTENT 481093.000000 4969319.036682 502271.000000 4997508.3073184
> # STATUS ON
> # COLOR -1 -1 -1
> # OUTLINECOLOR 255 0 0
> #END
> # Start of legend
> LEGEND
> KEYSIZE 18 12
> LABEL
> TYPE BITMAP
> SIZE MEDIUM
> COLOR 0 0 89
> END
> STATUS ON
> END
> # Start of scalebar
> SCALEBAR
> LABEL
> COLOR 0 0 0
> SIZE SMALL
> END
> SIZE 350 5
> COLOR 255 255 255
> BACKGROUNDCOLOR 0 0 0
> OUTLINECOLOR 0 0 0
> UNITS MILES
> INTERVALS 5
> STATUS ON
> END
> # Start of layer definitions
> LAYER
> NAME county
> TYPE POLYGON
> STATUS DEFAULT
> DATA county
> CLASS
> SYMBOL 0
> OUTLINECOLOR 0 0 0
> COLOR 248 248 95
> END
> END
> END # Layer
> END # Map File
> ****************************************demo.html
> ******************************While I obviously don't have all this
> stuff, I thought
> ******************************what I did have would display. Oh well.
> <html>
> <head><title>MapServer Demo Interface</title></head>
> <body bgcolor=#FFFFFF>
> <center><h1>MapServer Demo Interface</h1></center>
> <hr>
> <center>
> <table border=2 cellpadding=10 width=100%>
> <tr>
> <td align=center>
> <INPUT NAME="img" TYPE="image" SRC="[img]" width=600 height=600></A><p>
> <img src="[scalebar]">
> </td>
> <td>
> <input type="submit" value="Refresh/Query"><p>
> <input type="radio" name="mode" value="browse" checked> <b>Browse
> map</b><br>
> <input type="radio" name="mode" value="query"> <b>Query feature</b><br>
> <input type="radio" name="mode" value="nquery"> <b>Query multiple
> features</b>
> <hr>
> <center><a
> href="/cgi-bin/mapserv?map=[map]&mapext=[minx]+[miny]+[maxx]+[maxy]&mode=nquery&[get_layers
> ]">summarize</a></center>
> <hr>
> <p>
> <b>Select Layers to Display: </b><br>
> <select multiple name="layer" size=3>
> <option value="cities" [cities_select]> City Names
> <option value="lakes" [lakes_select]> Lakes
> <option value="streams" [streams_select]> Streams
> <option value="primary_roads" [primary_roads_select]> Primary Roads
> <option value="secondary_roads" [secondary_roads_select]> Secondary
> Roads
> <option value="railroad" [railroad_select]> Railroads
> <option value="runways" [runways_select]> Airport Runways
> <option value="landsat" [landsat_select]> Landsat TM Image
> </select>
> <p>
> Zoom In <input type=radio name=zoomdir value=1 [zoomdir_1_check]>
> Pan <input type=radio name=zoomdir value=0 [zoomdir_0_check]>
> Zoom Out <input type=radio name=zoomdir value=-1 [zoomdir_-1_check]>
> <p>
> Zoom Size <input type=text name=zoomsize size=4 value=[zoomsize]>
> <p>
> <font size=+1><b>Legend</b></font><br><hr>
> <img src="[legend]"><hr>
> <p>
> <INPUT NAME="ref" TYPE="image" SRC="[ref]" border="0"></A><p>
> </td>
> </tr>
> </table>
> </center>
> <input type="hidden" name="imgxy" value="299.5 299.5">
> <input type="hidden" name="imgext" value="[mapext]">
> <input type="hidden" name="map" value="[map]">
> </form>
> <p><hr><p>
> </body>
> </HTML>
> Sara W. Yurman
> Spatial Focus, Inc.
> email: syurman at spatialfocus.com
> voice: (404) 378-0989
> fax: (209) 254-9531
