Using query template's and javascript
bfischer at usgs.gov
Wed Apr 26 13:32:44 EDT 2000
Thanks to the people who responed to my original question. I figured out
what was causing the error in the javascipt. It turns out I had to put an
escape character (/) in front of the parenthes used in the table tags.
Ex.)
document.write("<td width=\"25%\">[BASIN_NAME]</td>\n");
Brian Fischer
USGS WRD
2280 Woodale Dr.
Mounds View, MN
(612) 783-3133
"Stephen Lime"
<steve.lime at dnr.st To: <bfischer at usgs.gov>
ate.mn.us> cc:
Subject: Re: Using query template's and javascript
04/24/00 01:50 PM
MapServer doesn't add ANY html code itself. You must have a reference
to a blank template someplace, perhaps as a query template for a particular
type of result?
Steve
>>> <bfischer at usgs.gov> 04/24/00 01:39PM >>>
Mapserver users,
I am trying to use javascript, with a query header, footer, and template
files. I am fairly new to javascript, but maybe other people have some
insights on what is happening. What I am trying to do is sum polygons'
attributes, from the polygons that get returned by a query. I am using a
query header, footer, and template to return the results to the browser
inside a HTML table. Here is the part of the HTML files with the
JavaScript program. I am using the program within the body of my HTML
file. The problem is nothing happens. The code is there when I view the
page source in Netscape. One thing I did notice is mapserver adds this
between the header and template files.
<html>
<head>
<title>Blank page</title>
</head>
<body>
</body>
</html>
Is this whats messing up the javascript?
header file:
<table>
<script LANGUAGE="JavaScript">
<!-- This script sums the area and writes it to HTML
var tam=0.0 ;
tam
=[wsareami] ;
query template
tam=tam+[AREA_SQ_MI] ;
document.write("<tr>
\n") ;
document.write("<td width="25%">[MAJOR]</td>\n") ;
document.write
("<td width="25%">[AREA_SQ_MI]</td>\n") ;
document.write("</tr>\n") ;
query footer
document.write("Total Area is: ") ;
document.write(tam) ;
</script>
</table>
Thanks,
Brian Fischer
USGS WRD
2280 Woodale Dr.
Mounds View, MN
(612) 783-3133
