mapimage applet
marcelo jury
mjury at impsat1.com
Fri Aug 4 14:25:35 EDT 2000
Hi ALL,
with the intention of make mapimage applet loads a new image,
I tryied to use the " newMap(URLParam) " mapimage applet's method, but the
first problem comes
out trying to figure out how the URLParam should be set. Since it has to
be just a url to a pic, I guess "URLParam" could be
a URL kind of template instead of the HTML type, but I dont know how it
works:
/scripts/mapserver.exe?map=myMap.map?template=[img]
/scripts/mapserver.exe?map=myMap.map?template="/scripts/mapserver.exe?map=my
Map.map[img]
after many attempts, the result is the same...:
Content-type: text/html returnHTML(): Web application error. Malformed
template name.
so I run into another way: (Mode=map)
<input type="button"
onclick="javascript:document.mapimage.newMap('/scripts/mapserver.exe?map=[ma
p]&imgext=[minx]+[miny]+[maxx]+[maxy]&imgxy=[center_x]+[center_y]&layers=[ge
t_layers]&imgbox=-1+-1+-1+-1&mode=map')" value="Apply" >
but it brings nothing.
>From the source code of one of the results I took the url and pasted it
directly into the
browser... and confirmed that the url works properly.
If all this would work the idea was to move this button onclick's code to
a APPLET Tag onmouseup event... but unffortunatly this event is not
triggered.
It should at least in IE5 as this page at MSDN confirm:
http://msdn.microsoft.com/workshop/author/dhtml/reference/objects/applet.asp
Ok..thats all. THANKS A LOT FOR ANY COMMENT about this issues!
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20000804/331ce4f3/attachment.html
