Mapserv in command line mode ?
kenboss
kenboss at dilbert.dnr.state.mn.us
Tue Aug 15 09:54:00 EDT 2000
Yes, perl mapscript is the answer you're looking for. You'll find it in your
source distribution under mapscript/perl. You'll have to build it yourself; the
current configure script doesn't handle mapscript yet. There are a couple of
useful scripts in the examples subdirectory, documentation is online at
http://mapserver.gis.umn.edu/mapscript.html, and a working app is available for
inspection in the mapserver test suite at
http://arachnid.dnr.state.mn.us/ms_test/.
Have fun,
Ken Boss
> > Hi All,
> > I need to save several hundred images generated by successive Mapserv
> > queries to disk as GIFs. I'd ideally like to just call Mapserv from within a
> > Perl script and write the output to file but I can't do this. Does anyone
> > have any suggestions.
> Use the mapserver/perl interface (aka mapscript)?
