SDE
Ross.Searle at dnr.qld.gov.au
Tue Dec 19 01:59:29 EST 2000
I have got mapserver running with the SDE connection stuff. It works
brilliantly except for the querying part. When I try to query the SDE theme
through either an "nquery" or "item/value" I get the follow error returned
from mapserver
msOpenSHPFile(): Unable to access file. (Sde.qld_np_estate_dbase_poly,shape)
which from the message would suggest that mapserver is trying to treat it as
a shapefile and not an SDE theme when querying
Anyone got an ideas
Thanks
Ross
The information in this e-mail together with any attachments is
intended only for the person or entity to which it is addressed
and may contain confidential and/or privileged material.
Any form of review, disclosure, modification, distribution
and/or publication of this e-mail message is prohibited.
If you have received this message in error, you are asked to
inform the sender as quickly as possible and delete this message
and any copies of this message from your computer and/or your
computer system network.
