Segfault?
Frederic Marchand
bomek at bomek.yi.org
Wed Dec 20 20:13:35 EST 2000
Hey there! i just installed Apache 1.3.14 with PHP4.0.4 and
php_mapserver.so keep segfaulting! so, i compiled mapserver with mpatrol
to see what's going on and here is the output:
@(#) mpatrol 1.3.2 (00/12/18)
Copyright (C) 1997-2000 Graeme S. Roy
This is free software, and you are welcome to redistribute it under
certain
conditions; see the GNU Library General Public License for details.
For the latest mpatrol release and documentation,
visit http://www.cbmamiga.demon.co.uk/mpatrol.
Log file generated on Wed Dec 20 20:06:02 2000
system page size: 4096 bytes
default alignment: 4 bytes
overflow size: 0 bytes
overflow byte: 0xAA
allocation byte: 0xFF
free byte: 0x55
allocation stop: 0
reallocation stop: 0
free stop: 0
unfreed abort: 0
small boundary: 32 bytes
medium boundary: 256 bytes
large boundary: 2048 bytes
lower check range: -
upper check range: -
failure frequency: 0
failure seed: 977360761
prologue function: <unset>
epilogue function: <unset>
handler function: <unset>
log file: <unset>
profiling file: mpatrol.out
tracing file: mpatrol.trace
program filename: /usr/sbin/httpd
symbols read: 10762
autosave count: 0
freed queue size: 0
allocation count: 172
allocation peak: 36 (186679 bytes)
allocation limit: 0 bytes
allocated blocks: 36 (186679 bytes)
freed blocks: 0 (0 bytes)
free blocks: 6 (18121 bytes)
internal blocks: 57 (933888 bytes)
total heap usage: 1138688 bytes
total compared: 0 bytes
total located: 0 bytes
total copied: 0 bytes
total set: 592 bytes
total warnings: 0
total errors: 1
ERROR: [ILLMEM]: illegal memory access at address 0x00000000
0x00000000 not in heap
[Wed Dec 20 20:06:02 2000] [notice] child pid 3116 exit signal Aborted (6)
I hope this gonna help! I wonder why it try to access this address... It
is a mapserver bug, apache bug, mapserver bug or a human bug (in this
case, me...)
Thanks a lot!
