How-to scalable symbols and text
Ma
marin at here.is
Fri Feb 4 19:30:06 EST 2000
In the line.sym file which comes with 3.3.006 there is no ellipse type symbols.
Can you send me ellipse type line symbol(s) for 3.3.006?
I send here the line.sym I had before and and the line.sym from 3.3.006 now. Why doesn't work with
the first line.sym file with 3.3.006?
### the line.sym file from 3.3b
LineSet
# 1
Symbol
Type STYLED
Style
0 0
0 1
END # Style
END
# 2
Symbol
Type STYLED
Style
0 -1
0 0
0 1
END # Style
END
# 3
Symbol
Type STYLED
Style
3 0
END # Style
END
# 4
Symbol
Type STYLED
Style
6 0
END # Style
END
# 5
Symbol
Type STYLED
Style
3 0
3 1
END # Style
END
# 6
Symbol
Type STYLED
Style
6 0
6 1
END # Style
END
# 7
Symbol
Type STYLED
Style
3 -1
3 0
3 1
END # Style
END
# 8
Symbol
Type STYLED
Style
6 -1
6 0
6 1
END # Style
END
# 9
Symbol
Type STYLED
Style
0 -1
0 1
END # Style
END
# 10
Symbol
Type STYLED
Style
4 -1
4 1
END # Style
END
# 11
Symbol
Type STYLED
Style
0 -1
4 0
0 1
END # Style
END
# 12
Symbol
Type STYLED
Style
0 -1
8 0
0 1
END # Style
END
# 13
Symbol
Type ELLIPSE
Filled
transparent 0
POINTS
1 1
END
END
END # LineSet
## the line.sym from 3.3.006
LINESET
Symbol
Type STYLED
Style
0 0 0
1 0 0
END
END
Symbol
Type STYLED
Style
-1 0 0
0 0 0
1 0 0
END
END
Symbol
Type STYLED
Style
0 3 3
END
END
Symbol
Type STYLED
Style
0 6 6
END
END
Symbol
Type STYLED
Style
0 3 3
1 3 3
END
END
Symbol
Type STYLED
Style
0 6 6
1 6 6
END
END
Symbol
Type STYLED
Style
-1 3 3
0 3 3
1 3 3
END
END
Symbol
Type STYLED
Style
-1 6 6
0 6 6
1 6 6
END
END
Symbol
Type STYLED
Style
-1 0 0
1 0 0
END
END
Symbol
Type STYLED
Style
-1 6 6
1 6 6
END
END
Symbol
Type STYLED
Style
-1 0 0
0 6 6
1 0 0
END
END
Symbol
Type Styled
Style
-1 0 0
0 12 12
1 0 0
END
END
Symbol
Type STYLED
Style
-1 1 7
0 0 0
1 1 7
END
END
Symbol
Type STYLED
Style
-1 1 5
0 1 5
0 1 2
1 1 5
END
END
END # LineSet
Ma
Stephen Lime wrote:
> Hi: Works the same as before. Problem is the symbol you're tring to scale. Line symbols
> of type STYLED are not scalable. You have to use type ELLIPSE symbols. Here's an
> example of an filled ellipse symbol radius 1,1 (i.e. a circle). This is scalable and results in
> circular of varying sizes.
> Symbol
> Type ELLIPSE
> Filled
> Points
> 1 1
> END
> END
> With 3.3 you can define styles within any symbol type and therefore can get scaled, complex
> symbols as well. Your millage may vary. Type STYLED symbols use a single pixel width lines
> only. Symbols are admittedly hard to work with, but you can do some wild things with them as
> they're pretty flexible.
> Steve
> Stephen Lime
> Internet Applications Analyst
> Minnesota DNR
> 500 Lafayette Road
> St. Paul, MN 55155
> 651-297-2937
> >>> Ma <marin at here.is> 02/04/00 03:12PM >>>
> How to scale symbols and text in 3.3.006. I did this in 3.3b but now
> there is something different.
> Here is part of the map file:
> # --- roads -------
> LAYER
> NAME roads
> TYPE LINE
> STATUS OFF
> DATA roads
> TOLERANCE 0
> SYMBOLSCALE 1000000
> CLASSITEM RoadType
> CLASS
> NAME "Primary road"
> EXPRESSION "Pr"
> COLOR 255 000 00
> SYMBOL 2 # this is the symbol from the distribution 3.3.006
> MAXSIZE 5
> MINSIZE 1
> END
> END
> Any ideas?
> Ma
