Tif an wld file problems
Robert Chavez
rchavez at perseus.tufts.edu
Thu Feb 17 07:43:05 EST 2000
That was the problem. I saved it as an uncompressed 8-bit and it works jut
fine. Thanks for the tip!
Rob
On Wed, 16 Feb 2000, Doug Nebert wrote:
> It is possible that you have a 24-bit TIFF file. It will only
> render if it is 8-bit, or so I experienced a few months back.
> Try again by saving the TIF as 8-bit and see what happens.
> Doug.
> Robert Chavez wrote:
> > Greetings,
> > I started fooling around with displaying tifs using mapscript and I'm
> > having a problem rendering a tif image layer. I've run the demo package
> > and displayed the landsat tif with mapserver just fine, so I know
> > mapserver/script compiled with the tif libraries.
> > The tif originally had a .tfw file so I changed the extension to
> > .wld (it looks like this, units are in meters)
> > 1.32301253030703
> > 0.00000000000000
> > 0.00000000000000
> > -1.16784976858186
> > 531694.70377556235000
> > 181396.49239035073000
> > After the script runs I get a blank .gif file as a result, no rendering of
> > the tif in site. This leads me to believe there's an extent problem
> > somewhere but I'm not sure where. The image should fit within the extents
> > of the map file (see map file below), I should be getting something even
> > if at a very small scale. I thought .tfw files were structurally identical
> > with .wld files, or have I missed something?
> > MAP
> > NAME test
> > SIZE 500 500
> > EXTENT 520118.780 175873.500 534426.880 184948.500
> > UNITS METERS
> > SHAPEPATH "data"
> > LAYER
> > NAME stpauls
> > TYPE RASTER
> > STATUS ON
> > DATA stpauls.tif
> > END
> > END
> > Regards,
> > Robert Chavez
> > Perseus Project
> Douglas D. Nebert
> Clearinghouse Coordinator
> FGDC Secretariat Phone: +1 703 648 4151 Fax: +1 703 648-5755
> Pager Messaging: http://fgdclearhs.er.usgs.gov/dougmsg.html
