Complex query on Shapefiles attributes
bfischer at usgs.gov
Fri Feb 18 11:28:40 EST 2000
Hello Everyone,
I have a question regarding a query on a shapefile's attributes.
Here is what I am trying to do. I have an image where the user can click
on a polygon and retrieve it's attributes. This part I have working and
understand. Now I would like to take the value three of the attributes
from the polygon that the user selected and use it in a expression. Here
is an example of the logic: The user selected a polygon, from this I can
get the polygon's attributes called num1, num2, and num3. I want to use
the values of num1, num2, and num3 to put into a query or class expression
like ([num1] >= [num2] and [num1] <= [num3]). From this I would get a
number of selected polygons to return to the user in a map with all the
polygons highlighted. I am working with only the polygon features within
one shapefile.
Can this be done with mapserv or do I need to look at doing this in
Javascript or some other language? I would also like to comment on the
discussion of development tools for Mapserver. For myself an
Avenue/ArcView extension would be useful.
Any suggestions would be apprecieted,
Thanks.
Brian Fischer
USGS WRD
2280 Woodale Dr.
Mounds View, MN
(612) 783-3133
