Find Helps
Pericles S. Nacionales
pnaciona at gis.umn.edu
Thu Feb 24 14:37:08 EST 2000
Hi, Eric
Let's see... If you really want to work on Windows NT you probably should think about compiling MapServer for yourself. That said, there is a compiled binary available from the the MapServer site. This is probably what you would want to do initially.
I assume you know about web servers already. If not, then you need to install a web server on your computer--a couple of free ones: Microsoft IIS (free to use) and Apache.org's Apache server (free to use and modify code). You'll need to copy the MapServer executable to your web server's cgi-bin directory. From there you can start using MapServer.
Now, you also would want to download the symbol files and put it somewhere--doesn't have to be a web accesible directory. Now my suggestion would be to download the MapServer demo and get it to work on your server. If you would like to see the demo running on Windows NT, check http://128.101.73.80/mapserv/demo_init.html.
You can also look at http://128.101.73.154/projects/tutorial to get started on MapServer--this site is also running on Windows NT. It works fairly well except for the last example (prblems with the java applet).
Well this should keep you busy for a while. If you have more questions send it to the mapserver-users list. One final thing, MapServer on NT hasn't really been rigorously tested and isn't considered to be as stable as the ports on UNIX systems. Hopefully, it will work just fine for what you want to do.
Good luck!
-Perry N.
Research Assistant
Department of Forest Resources
University of Minnesota
(612) 625 5765
----- Original Message -----
To: steve.lime at dnr.state.mn.us
Sent: Tuesday, February 23, 1999 8:07 AM
Subject: Find Helps
Hi Steve,
Nice to meet you! I am a new user of mapserver, I come from Hong Kong, studing GIS and I am a final year student. I want to make a network model and put it in the web. I saw mapserver can free for develop web map, that great. But I have a big problem, that I have no more experience in programming. Actually I really want to make a web map for my project.
I using arcview 3.2, and network anaylst for my gis system. Also the server I prefer WinNT4.0 than the Unix.
Now I looking someone can carry me to make a web map server. I will appreciate more, if anyone can help.
Thanks a lot,
Eric Tang
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20000224/d2e09113/attachment.html
