Problems using tiled data
Joel Schlagel
joel at free.crrel.usace.army.mil
Mon Feb 28 12:17:57 EST 2000
The key word is TILEINDEX, rather than TILE
joel
On Mon, 28 Feb 2000, RAldridge wrote:
> I need help setting up my map file to use tiled data from an NFS source. My shapefiles are stored on NT in an NFS shared folder. The folder is mapped as "/gdata" on my linux box. The folder contains two subfolders; "County_Data" and "Statewide_Data." I can map individual shapefiles in my .map file fine. There is a shapefile containing the outlines of the counties at "/gdata/Statewide_Data/counties.shp" which has a field called LOCATION. The "/gdata/County_Data" folder contains a folder for each county. Each county's folder contains shapefiles for several data layers. My .map file contains the following, but I get "loadLayer(): Unknown identifier. (INDEX):(99)" when I try to use it. Any help would be appreciated.
> # Start of map file
> NAME DEMO
> STATUS ON
> SIZE 350 500
> SHADESET symbols/shade.sym
> MARKERSET symbols/marker.sym
> LINESET symbols/line.sym
> EXTENT -93.00 29.00 -86.00 36.00
> #EXTENT 254189.000000 1117801.000000 292781.000000 1151833.000000
> UNITS DD
> TILE "/gdata/Statewide_Data/"
> SHAPEPATH "/gdata/Statewide_Data"
> IMAGECOLOR 255 255 255
